Ana içeriğe geç
Ryobi RY42102 Leaf Blower Fan Replacement
Neye ihtiyacın var
  1. Ryobi RY42102 Leaf Blower Fan Replacement, Fan: adım 1, 3 resimden 1. Ryobi RY42102 Leaf Blower Fan Replacement, Fan: adım 1, 3 resimden 2. Ryobi RY42102 Leaf Blower Fan Replacement, Fan: adım 1, 3 resimden 3.
    • Lay the blower on its side so that most of the screw heads are facing up. Identify all 9 screw locations.
    • One screw is located under the sticker with the number 8 on it.
    • Another screw is located on the opposite side.
  2. Ryobi RY42102 Leaf Blower Fan Replacement: adım 2, 1 resimden 1.
    • Using a T15 torx drive(star-head), carefully remove each of the 9 screws and set aside in a secure location. All 9 screws are 10 mm long.
  3. Ryobi RY42102 Leaf Blower Fan Replacement: adım 3, 2 resimden 1. Ryobi RY42102 Leaf Blower Fan Replacement: adım 3, 2 resimden 2.
    • After all 9 screws have been removed, seperate the handle housing the on/off switch.
  4. Ryobi RY42102 Leaf Blower Fan Replacement: adım 4, 1 resimden 1.
    • Once the handle has been separated, the blower shaft with detach from the motor housing. Slide the blower shaft out of the motor housing and set aside.
    the handle is separated, but the blower shaft is not detached from the motor mousing , it wont slide or move, any suggestions??
    Jed - Yanıt
    I can't get it separated for the life of me without going nuclear on it. Feels glued together.
    Jerry Flowers - Yanıt
  5. Ryobi RY42102 Leaf Blower Fan Replacement: adım 5, 1 resimden 1.
    • Once the blower shaft is detached, the fan will be visible. Use a ratchet with a 1/2" socket to remove the 1/2" nut securing the fan to the motor. This nut is reverse thread so turning it clockwise will loosen it. The fan will also need to be secured so that it does not spin as the nut is being loosened.
  6. Ryobi RY42102 Leaf Blower Fan Replacement: adım 6, 3 resimden 1. Ryobi RY42102 Leaf Blower Fan Replacement: adım 6, 3 resimden 2. Ryobi RY42102 Leaf Blower Fan Replacement: adım 6, 3 resimden 3.
    • Remove new fan from package and install as shown. Screw the nut back on to secure the fan. Remember the nut is reverse thread, so turning it counter clockwise will tighten it. The fan will also need to be secured while the nut is being tightened.
  7. Ryobi RY42102 Leaf Blower Fan Replacement: adım 7, 3 resimden 1. Ryobi RY42102 Leaf Blower Fan Replacement: adım 7, 3 resimden 2. Ryobi RY42102 Leaf Blower Fan Replacement: adım 7, 3 resimden 3.
    • Slide blower shaft back into motor housing, close handle back around blower shaft and motor housing, and screw all 9 screws back into their location.
    Thank you! This worked great once we read where the screw was underneath the sticker! And then it was easy peasy. Make sure you pull on it good to get the nozzle off.
    Jj KH - Yanıt
Sonuç
Take leaf blower outside before operating to evaluate repair success.
2 farklı kişi bu kılavuzu tamamladı.
7 Yorum
Thank you!!! Exactly what I needed!
EK1914 - Yanıt
My blower is not like yours. Mine like a fun has corn shaped. How to replace this fun. I need your help.
Jerome Hatano - Yanıt
Thanks for the tip, mine is a cordless 18 v and it's slightly more difficult then shown but not impossible!!
It's all plastic and kinda worried about breaking something. I've had mine like for almost 2 yrs. I was using it and barely bumped the wall and the blade just exploded….Really crazy weird.
Thanks for the help.
Clint Porter - Yanıt
Cannot find the correct part on the internet anywhere. Mine is orange and flat on the back side; not coned & green as shown in your tutorial.
Jan Dru Basehart
Jan D Basehart - Yanıt
Jan I believe mine was orange originally as well. I would try to contact their parts department to ensure it will work before ordering though.
Justin Hannah - Yanıt
Recently stopped running - fan isn’t physically damaged that I can see. Thought I needed a new battery, but new battery didn’t fix. any ideas if this is symptomatic of a bad fan? anything else?
Adam Frank - Yanıt
For anyone looking for the fan, you can see from the parts list (https://ryobipower.ordertree.com/media/m...) that the part is 529410003 https://ryobipower.ordertree.com/catalog...
Chris Rink - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 25
Son 30 gün: 93
Her zaman: 13,176
