Giriş
This guide will show you how to replace the fuel lines and filter on your Ryobi RY253SS String Trimmer. It requires no prior experience in small engine repair.
The fuel filter, for this model string trimmer, needs to be replaced either after 25 hours of run time or each year. The filter ensures that debris does not enter the fuel system of the engine, thus maintaining proper performance of your string trimmer. Another reason you may need to replace the fuel filter is if you have not been using the proper fuel to oil ratio in the fuel mixture. This can cause the engine problems when starting. This fix can breathe new life into your string trimmer and have it running similar to the day you got it out of the box.
Neye ihtiyacın var
With your hands, remove the air filter cover from your edge trimmer.
Remove the air filter before moving to the next step.
To reassemble your device, follow steps 1 and 2 in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
