Ana içeriğe geç
Ryobi VC120 Motor Replacement
Neye ihtiyacın var
  1. Ryobi VC120 Motor Replacement, Filter: adım 1, 1 resimden 1.
    • Pull the black nose off of the body of the vacuum, by pushing in the orange button closest to the nose.
  2. Ryobi VC120 Motor Replacement: adım 2, 2 resimden 1. Ryobi VC120 Motor Replacement: adım 2, 2 resimden 2.
    • Grab the filter with two fingers and slide it out.
  3. Ryobi VC120 Motor Replacement, Motor: adım 3, 2 resimden 1. Ryobi VC120 Motor Replacement, Motor: adım 3, 2 resimden 2.
    • Using a Philips head screwdriver, remove the four screws located on the side panel of the vacuum.
    • There are two types of screws on this device. You may want to use a magnetic screw pad to organize your screws to be sure they return to their designated holes.
    • 4x 19.1mm
    • 1x 14.3mm
    • Once the screws are removed, you should be able to separate the side panel from the rest of the device.
  4. Ryobi VC120 Motor Replacement: adım 4, 3 resimden 1. Ryobi VC120 Motor Replacement: adım 4, 3 resimden 2. Ryobi VC120 Motor Replacement: adım 4, 3 resimden 3.
    • Pull your motor out, and remove the black and red cables from the motor by hand.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Allison Schoch
689 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-4, Baechle Fall 2015 IUPUI, Team 2-4, Baechle Fall 2015 üyesi
IUPUI-BAECHLE-F15S2G4
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 817
