Ana içeriğe geç
SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement
Neye ihtiyacın var
  1. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement, Battery: adım 1, 2 resimden 1. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the ten 4.3mm Phillips #00 screws from the bottom cover of the laptop.
  2. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: adım 2, 3 resimden 1. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: adım 2, 3 resimden 2. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: adım 2, 3 resimden 3.
    • Press the button to release the bottom cover.
  3. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: adım 3, 2 resimden 1. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: adım 3, 2 resimden 2.
    • Remove the five 4.3mm Phillips #00 screws from the battery.
  4. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: adım 4, 2 resimden 1. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: adım 4, 2 resimden 2.
    • Lift the battery with both hands and remove.
  5. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement, Screen: adım 5, 3 resimden 1. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement, Screen: adım 5, 3 resimden 2. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement, Screen: adım 5, 3 resimden 3.
    • Disconnect the display cable from the motherboard.
  6. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: adım 6, 2 resimden 1. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: adım 6, 2 resimden 2.
    • Disconnect the black and white antenna cables from the Wi-Fi card.
  7. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: adım 7, 2 resimden 1. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: adım 7, 2 resimden 2.
    • Remove the five 4mm Phillips #00 screws from the motherboard retaining brackets.
  8. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: adım 8, 2 resimden 1. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: adım 8, 2 resimden 2.
    • Remove the eight silver 4.2mm Phillips #00 screws from the corner.
  9. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: adım 9, 3 resimden 1. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: adım 9, 3 resimden 2. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: adım 9, 3 resimden 3.
    • Pry up the metal hinges from the laptop.
  10. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: adım 10, 3 resimden 1. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: adım 10, 3 resimden 2. SAMSUNG ATIV Book 9 Plus NP930X5J-S01US Screen Replacement: adım 10, 3 resimden 3.
    • Place the screen on its back side and hold the battery-side of the laptop. In an upward motion, remove the back set off and set it aside.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sean Kim
640 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G2, Liner Spring 2018 UW Tacoma, Team S1-G2, Liner Spring 2018 üyesi
UWT-LINER-S18S1G2
5 Üyeler
Bir Yorum
There’s no need to remove the battery. Just disconnect its power socket if you want to be ‘careful’.
Steerpike - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 594
