Ana içeriğe geç
SEGA Genesis Flashback Back Cover Replacement
Neye ihtiyacın var
  1. SEGA Genesis Flashback Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • Scratch off the right-hand side of the sticker at the center of the bottom case using the spudger until the screw is visible.
    • Remove this screw with the Phillips #000 screwdriver.
    FixBot'a Sor
  2. SEGA Genesis Flashback Back Cover Replacement: adım 2, 1 resimden 1.
    • Remove the two visible screws on the bottom with the Phillips #000 screwdriver.
    FixBot'a Sor
  3. SEGA Genesis Flashback Back Cover Replacement: adım 3, 2 resimden 1. SEGA Genesis Flashback Back Cover Replacement: adım 3, 2 resimden 2.
    • Use your fingers to peel off the four corner rubber feet on the bottom.
    • Use the Phillips #000 screwdriver to remove the four screws beneath the rubber feet.
    FixBot'a Sor
  4. SEGA Genesis Flashback Back Cover Replacement: adım 4, 1 resimden 1.
    • Flip the case to its upright position.
    • Place one hand on the bottom plate of the case and one on the top plate. Gently pull apart the two plates by tilting the top plate about the front of the device. Treat the front of the device as a hinge.
    • Remove the back cover from the device.
    • Be sure not to rip the wire connection of the LED bulb that is still connected to the bottom plate.
    FixBot'a Sor
Sonuç
Bir başkası bu kılavuzu tamamladı.
Viet Nguyen
220 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S24-G12, Maness Spring 2018 Cal Poly, Team S24-G12, Maness Spring 2018 üyesi
CPSU-MANESS-S18S24G12
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 78
Her zaman: 1,001
