Ana içeriğe geç
SG 552-1 Commando Safety Replacement
Neye ihtiyacın var
  1. SG 552-1 Commando Safety Replacement, Gearbox: adım 1, 2 resimden 1. SG 552-1 Commando Safety Replacement, Gearbox: adım 1, 2 resimden 2.
    • Using a flathead screwdriver, remove the pin holding the hand guard in place.
    • To remove this, turn the pin clockwise and push it through at the same time.
    • Remove the hand guard.
  2. SG 552-1 Commando Safety Replacement: adım 2, 2 resimden 1. SG 552-1 Commando Safety Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun.
    • There should be four total.
  3. SG 552-1 Commando Safety Replacement: adım 3, 2 resimden 1. SG 552-1 Commando Safety Replacement: adım 3, 2 resimden 2.
    • Turn the gun over so that you are facing the bottom of the gun.
    • Using a Phillips #1 screwdriver, remove the following screws:
    • Remove the 8mm screw that is located directly underneath the cocking lever.
    • Remove the 8mm screw located beside the screw you just removed.
  4. SG 552-1 Commando Safety Replacement: adım 4, 2 resimden 1. SG 552-1 Commando Safety Replacement: adım 4, 2 resimden 2.
    • Carefully tug on the tip of the gun and pull the barrel and its cover out.
  5. SG 552-1 Commando Safety Replacement: adım 5, 3 resimden 1. SG 552-1 Commando Safety Replacement: adım 5, 3 resimden 2. SG 552-1 Commando Safety Replacement: adım 5, 3 resimden 3.
    • Locate the hand grip.
    • Using a Phillips #0 screwdriver, remove the two 6mm screws at the bottom of the hand grip.
    • Slide the cover off.
  6. SG 552-1 Commando Safety Replacement: adım 6, 2 resimden 1. SG 552-1 Commando Safety Replacement: adım 6, 2 resimden 2.
    • Pull the motor out of the hand grip.
    • Using a Phillips #1 screwdriver, remove the two 5mm screws inside of the hand grip.
  7. SG 552-1 Commando Safety Replacement: adım 7, 2 resimden 1. SG 552-1 Commando Safety Replacement: adım 7, 2 resimden 2.
    • Locate the pin holding the folding stock in place.
    • Using an allen wrench or something small, carefully push the pin out.
  8. SG 552-1 Commando Safety Replacement: adım 8, 2 resimden 1. SG 552-1 Commando Safety Replacement: adım 8, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the 20mm screw behind the folding stock and above the gearbox.
    • Remove the cover that was held on by the screw.
  9. SG 552-1 Commando Safety Replacement: adım 9, 3 resimden 1. SG 552-1 Commando Safety Replacement: adım 9, 3 resimden 2. SG 552-1 Commando Safety Replacement: adım 9, 3 resimden 3.
    • Using a flathead screwdriver, remove the two 5mm screws beside the safety switch on both sides of the gun.
    • Slide off the piece that was held on by those screws.
  10. SG 552-1 Commando Safety Replacement: adım 10, 2 resimden 1. SG 552-1 Commando Safety Replacement: adım 10, 2 resimden 2.
    • Using a small allen wrench, carefully unscrew the screws holding the safety switch in place on both sides of the gun.
    • The screws do not have to be taken out all the way, just slightly loosen them until you are able to pull the switch off.
  11. SG 552-1 Commando Safety Replacement: adım 11, 2 resimden 1. SG 552-1 Commando Safety Replacement: adım 11, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the two 6mm screws that were underneath the safety switch on both sides of the gun.
    • Carefully remove the pieces that were held on by the screws.
  12. SG 552-1 Commando Safety Replacement: adım 12, 3 resimden 1. SG 552-1 Commando Safety Replacement: adım 12, 3 resimden 2. SG 552-1 Commando Safety Replacement: adım 12, 3 resimden 3.
    • Pull apart the cover when pulling the gearbox out.
    • Pull the gearbox out.
    • The gears will fall out when taking the gearbox out. Careful not to lose them.
  13. SG 552-1 Commando Safety Replacement, Safety: adım 13, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the single 3mm screw holding the safety/trigger cover in place.
  14. SG 552-1 Commando Safety Replacement: adım 14, 2 resimden 1. SG 552-1 Commando Safety Replacement: adım 14, 2 resimden 2.
    • Remove the cover over the trigger.
    • The safety is located underneath the cover.
Sonuç
Anika Morris
1 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-41, Regan Fall 2012 Cal Poly, Team 18-41, Regan Fall 2012 üyesi
CPSU-REGAN-F12S18G41
6 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 9
Her zaman: 712
