Ana içeriğe geç
SG 552-1 Commando Spring Replacement
Neye ihtiyacın var
  1. SG 552-1 Commando Spring Replacement, Gearbox: adım 1, 2 resimden 1. SG 552-1 Commando Spring Replacement, Gearbox: adım 1, 2 resimden 2.
    • Using a flathead screwdriver, remove the pin holding the hand guard in place.
    • To remove this, turn the pin clockwise and push it through at the same time.
    • Remove the hand guard.
    FixBot'a Sor
  2. SG 552-1 Commando Spring Replacement: adım 2, 2 resimden 1. SG 552-1 Commando Spring Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun.
    • There should be four total.
    FixBot'a Sor
  3. SG 552-1 Commando Spring Replacement: adım 3, 2 resimden 1. SG 552-1 Commando Spring Replacement: adım 3, 2 resimden 2.
    • Turn the gun over so that you are facing the bottom of the gun.
    • Using a Phillips #1 screwdriver, remove the following screws:
    • Remove the 8mm screw that is located directly underneath the cocking lever.
    • Remove the 8mm screw located beside the screw you just removed.
    FixBot'a Sor
  4. SG 552-1 Commando Spring Replacement: adım 4, 2 resimden 1. SG 552-1 Commando Spring Replacement: adım 4, 2 resimden 2.
    • Carefully tug on the tip of the gun and pull the barrel and its cover out.
    FixBot'a Sor
  5. SG 552-1 Commando Spring Replacement: adım 5, 3 resimden 1. SG 552-1 Commando Spring Replacement: adım 5, 3 resimden 2. SG 552-1 Commando Spring Replacement: adım 5, 3 resimden 3.
    • Locate the hand grip.
    • Using a Phillips #0 screwdriver, remove the two 6mm screws at the bottom of the hand grip.
    • Slide the cover off.
    FixBot'a Sor
  6. SG 552-1 Commando Spring Replacement: adım 6, 2 resimden 1. SG 552-1 Commando Spring Replacement: adım 6, 2 resimden 2.
    • Pull the motor out of the hand grip.
    • Using a Phillips #1 screwdriver, remove the two 5mm screws inside of the hand grip.
    FixBot'a Sor
  7. SG 552-1 Commando Spring Replacement: adım 7, 2 resimden 1. SG 552-1 Commando Spring Replacement: adım 7, 2 resimden 2.
    • Locate the pin holding the folding stock in place.
    • Using an allen wrench or something small, carefully push the pin out.
    FixBot'a Sor
  8. SG 552-1 Commando Spring Replacement: adım 8, 2 resimden 1. SG 552-1 Commando Spring Replacement: adım 8, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the 20mm screw behind the folding stock and above the gearbox.
    • Remove the cover that was held on by the screw.
    FixBot'a Sor
  9. SG 552-1 Commando Spring Replacement: adım 9, 3 resimden 1. SG 552-1 Commando Spring Replacement: adım 9, 3 resimden 2. SG 552-1 Commando Spring Replacement: adım 9, 3 resimden 3.
    • Using a flathead screwdriver, remove the two 5mm screws beside the safety switch on both sides of the gun.
    • Slide off the piece that was held on by those screws.
    FixBot'a Sor
  10. SG 552-1 Commando Spring Replacement: adım 10, 2 resimden 1. SG 552-1 Commando Spring Replacement: adım 10, 2 resimden 2.
    • Using a small allen wrench, carefully unscrew the screws holding the safety switch in place on both sides of the gun.
    • The screws do not have to be taken out all the way, just slightly loosen them until you are able to pull the switch off.
    FixBot'a Sor
  11. SG 552-1 Commando Spring Replacement: adım 11, 2 resimden 1. SG 552-1 Commando Spring Replacement: adım 11, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the two 6mm screws that were underneath the safety switch on both sides of the gun.
    • Carefully remove the pieces that were held on by the screws.
    FixBot'a Sor
  12. SG 552-1 Commando Spring Replacement: adım 12, 3 resimden 1. SG 552-1 Commando Spring Replacement: adım 12, 3 resimden 2. SG 552-1 Commando Spring Replacement: adım 12, 3 resimden 3.
    • Pull apart the cover when pulling the gearbox out.
    • Pull the gearbox out.
    • The gears will fall out when taking the gearbox out. Careful not to lose them.
    FixBot'a Sor
  13. SG 552-1 Commando Spring Replacement, Spring: adım 13, 2 resimden 1. SG 552-1 Commando Spring Replacement, Spring: adım 13, 2 resimden 2.
    • Remove these four 15mm screws.
    • Remove this single 8mm screw.
    • Using a Phillips #0 screwdriver, remove the following screws:
    • Remove this single 3mm screw.
    • Remove this single 14mm screw.
    • Detach the pieces unscrewed from the gearbox.
    FixBot'a Sor
  14. SG 552-1 Commando Spring Replacement: adım 14, 2 resimden 1. SG 552-1 Commando Spring Replacement: adım 14, 2 resimden 2.
    • Remove the piece covering the trigger.
    • Remove the safety piece.
    • Using a Phillips #1 screwdriver, remove the 18mm screw beside the trigger.
    FixBot'a Sor
  15. SG 552-1 Commando Spring Replacement: adım 15, 1 resimden 1.
    • Remove the metal piece.
    • Removing this piece will permanently damage the metal piece.
    FixBot'a Sor
  16. SG 552-1 Commando Spring Replacement: adım 16, 3 resimden 1. SG 552-1 Commando Spring Replacement: adım 16, 3 resimden 2. SG 552-1 Commando Spring Replacement: adım 16, 3 resimden 3.
    • Remove the cover and pull out the spring.
    FixBot'a Sor
Sonuç
Anika Morris
1 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-41, Regan Fall 2012 Cal Poly, Team 18-41, Regan Fall 2012 üyesi
CPSU-REGAN-F12S18G41
6 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
When i read step 15 it seems impossible to up/downgrade spring without damaging the gun permanently??
Marco den Hartog - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 71
Her zaman: 2,263
