Ana içeriğe geç
SGH-A117 keypad replacement
Neye ihtiyacın var
    1. SGH-A117 keypad replacement, Battery: adım 1, 1 resimden 1.
      • Remove the battery by pressing the battery lock down and slide the battery cover away.
      FixBot'a Sor
      Yorum Ekle
    2. SGH-A117 keypad replacement: adım 2, 1 resimden 1.
      • Lift the bottom of the battery and then move it up and away.
      FixBot'a Sor
      Yorum Ekle
    1. SGH-A117 keypad replacement, Motherboard: adım 3, 1 resimden 1.
      • Locate the 4 screws holes on the phone and remove them with the #000 Philips Head screwdriver. (See red circles)
      FixBot'a Sor
      Yorum Ekle
    2. SGH-A117 keypad replacement: adım 4, 1 resimden 1.
      • Using the plastic opening tool, gently pry open the back piece of the phone.
      • Make sure to do this very carefully, as the back part of the phone is very thin and fragile.
      FixBot'a Sor
      Yorum Ekle
    3. SGH-A117 keypad replacement: adım 5, 1 resimden 1.
      • Use the metal prying tool to gently flick up the rectangular connector. (Because this device is on the smaller side, the rectangular connector may only need a simple flick with the prying tool)
      • Simply flick the rectangular connector up from its socket. (Highlighted by the red square)
      FixBot'a Sor
      Yorum Ekle
    4. SGH-A117 keypad replacement: adım 6, 1 resimden 1.
      • Use the plastic opening tool to gently pry up the motherboard.
      • You may need to pry the motherboard up from several angles in order to remove it.
      FixBot'a Sor
      Yorum Ekle
    1. SGH-A117 keypad replacement, Keypad: adım 7, 1 resimden 1.
      • After the connector has been removed you will gently pull off the mother board, which will reveal the rubber keypad.
      FixBot'a Sor
      Yorum Ekle
    2. SGH-A117 keypad replacement: adım 8, 1 resimden 1.
      • Replace the faulty keypad, and reassemble the phone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Stephanie Isaac
431 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 37
Her zaman: 582
