Ana içeriğe geç
SHARP EL-W53XG WriteView Battery Replacement
Neye ihtiyacın var
  1. SHARP EL-W53XG WriteView  Battery Replacement, Battery: adım 1, 2 resimden 1. SHARP EL-W53XG WriteView  Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn off the calculator by pressing both the [2NDF ] and [ON] buttons at the same time.
  2. SHARP EL-W53XG WriteView  Battery Replacement: adım 2, 1 resimden 1.
    • Flip the calculator so that the battery cover is facing you, and it will be easy to remove.
  3. SHARP EL-W53XG WriteView  Battery Replacement: adım 3, 2 resimden 1. SHARP EL-W53XG WriteView  Battery Replacement: adım 3, 2 resimden 2.
    • Remove the two screws securing the battery cover with the Tri-point #000 screwdriver.
    • Remove the battery cover.
    • Make sure not to remove the other screws on the calculator, just the two screws on the battery cover.
  4. SHARP EL-W53XG WriteView  Battery Replacement: adım 4, 2 resimden 1. SHARP EL-W53XG WriteView  Battery Replacement: adım 4, 2 resimden 2.
    • Remove the worn-out LR44 battery inside using a spudger.
  5. SHARP EL-W53XG WriteView  Battery Replacement: adım 5, 1 resimden 1.
    • Gently insert the new LR44 battery in the empty battery slot.
  6. SHARP EL-W53XG WriteView  Battery Replacement: adım 6, 1 resimden 1.
    • Place and screw the battery cover on using the Tri-point #000 screwdriver.
    • Tightly screw the battery cover to prevent losing screws.
Sonuç
Faduma Hagi
133 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 34
Her zaman: 1,497
