Ana içeriğe geç
SIM Card Slot Repair
Neye ihtiyacın var
  1. SIM Card Slot Repair, SIM Card Slot Repair: adım 1, 3 resimden 1. SIM Card Slot Repair, SIM Card Slot Repair: adım 1, 3 resimden 2. SIM Card Slot Repair, SIM Card Slot Repair: adım 1, 3 resimden 3.
    • Start by getting your work space set up and clear of clutter.
    • Remove the back of the phone.
    • Remove the battery and set it aside.
    FixBot'a Sor
    Yorum Ekle
  2. SIM Card Slot Repair: adım 2, 2 resimden 1. SIM Card Slot Repair: adım 2, 2 resimden 2.
    • Remove the six 2.3mm screws with a "T5" Screwdriver.
    • Remove the 2 additional 2.3mm screws from the side opposite the volume and power button.
    • When you open the back of the phone the camera and speaker will be attached to the part that you are removing.
    FixBot'a Sor
    Yorum Ekle
  3. SIM Card Slot Repair: adım 3, 3 resimden 1. SIM Card Slot Repair: adım 3, 3 resimden 2. SIM Card Slot Repair: adım 3, 3 resimden 3.
    • Inspect the sim slot to find where the factory solder might be broken.
    • Once found dip the soldering gun in the flux to prevent the solder sticking to the gun.
    • Use the 60/40 lead solder to repair the damaged spot on the sim slot.
    • Do NOT allow the solder to touch any other connections as it could cause the device to short out or no function properly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
I recently purchased a custom built phone which has the best parts of Android with the IMAX 13 camera my SIM tray broke and I can't seem to find anyone that has or knows which kind goes here is there any way you could help me
Bryan S. - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 31
Son 30 gün: 113
Her zaman: 15,600
