Ana içeriğe geç
SKYTEX SP1020 Battery Replacement
Neye ihtiyacın var
    1. SKYTEX SP1020 Battery Replacement, Rear Case: adım 1, 2 resimden 1. SKYTEX SP1020 Battery Replacement, Rear Case: adım 1, 2 resimden 2.
      • Prior to any repairs make sure that you are familiar with the device as well as the location of its buttons and ports.
      • Turn off device prior to continuing to further steps.
      FixBot'a Sor
      Yorum Ekle
    2. SKYTEX SP1020 Battery Replacement: adım 2, 3 resimden 1. SKYTEX SP1020 Battery Replacement: adım 2, 3 resimden 2. SKYTEX SP1020 Battery Replacement: adım 2, 3 resimden 3.
      • Set the tablet back panel facing down, with the SKYTEX logo facing you. You will find that this step will start from the right side of the device.
      • Insert the plastic opening tool between the bottom seam of the back panel and the micro SD port. The tool's edge should point toward the rear panel to prevent any scratching or damage.
      • Follow up with the plastic opening tool, releasing the clips as you go all the way around the device.
      FixBot'a Sor
      Yorum Ekle
    3. SKYTEX SP1020 Battery Replacement: adım 3, 1 resimden 1.
      • The clips will be released in the order specified as the spudger tool is moved along the seam around the device.
      FixBot'a Sor
      Yorum Ekle
    4. SKYTEX SP1020 Battery Replacement: adım 4, 1 resimden 1.
      • Use a plastic opening tool to pry the speakers out of the rear case.
      • The rear case will now be free from the rest of the device.
      FixBot'a Sor
      Yorum Ekle
    1. SKYTEX SP1020 Battery Replacement, Battery: adım 5, 1 resimden 1.
      • Locate the battery.
      FixBot'a Sor
      Yorum Ekle
    2. SKYTEX SP1020 Battery Replacement: adım 6, 1 resimden 1.
      • Use a soldering iron and desoldering braid to desolder the red and black motherboard battery connections.
      FixBot'a Sor
      Yorum Ekle
    3. SKYTEX SP1020 Battery Replacement: adım 7, 1 resimden 1.
      • Gently lift the battery up and out of the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Anthony Vitali
293 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Miles Spring 2015 UMass Dartmouth, Team 1-6, Miles Spring 2015 üyesi
UMASSD-MILES-S15S1G6
4 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
Great Instructions! where did you get the battery for the Skytex ?
joe_capozzi - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 31
Her zaman: 1,075
