Ana içeriğe geç
SKYTEX SP1020 Speakers Replacement
Neye ihtiyacın var
  1. SKYTEX SP1020 Speakers Replacement, Rear Case: adım 1, 2 resimden 1. SKYTEX SP1020 Speakers Replacement, Rear Case: adım 1, 2 resimden 2.
    • Prior to any repairs make sure that you are familiar with the device as well as the location of its buttons and ports.
    • Turn off device prior to continuing to further steps.
  2. SKYTEX SP1020 Speakers Replacement: adım 2, 3 resimden 1. SKYTEX SP1020 Speakers Replacement: adım 2, 3 resimden 2. SKYTEX SP1020 Speakers Replacement: adım 2, 3 resimden 3.
    • Set the tablet back panel facing down, with the SKYTEX logo facing you. You will find that this step will start from the right side of the device.
    • Insert the plastic opening tool between the bottom seam of the back panel and the micro SD port. The tool's edge should point toward the rear panel to prevent any scratching or damage.
    • Follow up with the plastic opening tool, releasing the clips as you go all the way around the device.
  3. SKYTEX SP1020 Speakers Replacement: adım 3, 1 resimden 1.
    • The clips will be released in the order specified as the spudger tool is moved along the seam around the device.
  4. SKYTEX SP1020 Speakers Replacement: adım 4, 1 resimden 1.
    • Use a plastic opening tool to pry the speakers out of the rear case.
    • The rear case will now be free from the rest of the device.
  5. SKYTEX SP1020 Speakers Replacement, Speakers: adım 5, 1 resimden 1.
    • locate the speakers
  6. SKYTEX SP1020 Speakers Replacement: adım 6, 2 resimden 1. SKYTEX SP1020 Speakers Replacement: adım 6, 2 resimden 2.
    • Use a soldering iron and desoldering braid to desolder the two sets of red and black wires.
  7. SKYTEX SP1020 Speakers Replacement: adım 7, 1 resimden 1.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Anthony Vitali
293 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Miles Spring 2015 UMass Dartmouth, Team 1-6, Miles Spring 2015 üyesi
UMASSD-MILES-S15S1G6
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 89
