Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Take apart the steel strap for the watch by using the round head (SIM) screwdriver. Then pull out the screw.
Remove four screws from the back cover using the Y000 screwdriver .
Remove the back cover of the watch using the opening tool.
Remove the plastic gasket from on top of the battery using the opening tool.
Loosen the battery bracket from the watch by placing the 1mm flathead screwdriver under and lifting carefully.
Take the old battery out using the plastic opening tool or spudger.
