Ana içeriğe geç
SONOS ZP100 Network Card Replacement
Neye ihtiyacın var
    1. SONOS ZP100 Network Card Replacement, Lets begin!: adım 1, 2 resimden 1. SONOS ZP100 Network Card Replacement, Lets begin!: adım 1, 2 resimden 2.
      • With the SONOS ZP100 (ZonePlayer) you can use external speakers to play your music that is streamed to the Sonos ZP100 via WiFi or cable.
      • The mute button and the volume buttons are located on the front.
      • On the back are the the four Ethernet ports, the connections for the speakers, subwoofer, audio-in and the power supply.
      • The integrated amplifier delivers an output of 2 x 50 watts.
      • With the Sonos S1 System App, the ZP100 can be controlled via a smartphone or a computer.
      FixBot'a Sor
      Yorum Ekle
    2. SONOS ZP100 Network Card Replacement, Remove cover: adım 2, 2 resimden 1. SONOS ZP100 Network Card Replacement, Remove cover: adım 2, 2 resimden 2.
      • The upper cover is fastened with two retaining lugs on the front and two on the sides.
      • There are fixed brackets on the back that cannot be pressed in.
      FixBot'a Sor
      Yorum Ekle
    3. SONOS ZP100 Network Card Replacement: adım 3, 3 resimden 1. SONOS ZP100 Network Card Replacement: adım 3, 3 resimden 2. SONOS ZP100 Network Card Replacement: adım 3, 3 resimden 3.
      • Gently try to lift one side with a metal spudger. Make sure not to press in the retaining lug directly, as it can break off very easily.
      • When you've lifted one side, use an Opening Pick to keep the lid from snapping back into place.
      • Lift the lid up and out of its mounting towards the back.
      • Sharp-edged tools can cause scratches and leverage, which later remain visible on the device.
      FixBot'a Sor
      Yorum Ekle
    4. SONOS ZP100 Network Card Replacement, Remove the screws from the upper case: adım 4, 3 resimden 1. SONOS ZP100 Network Card Replacement, Remove the screws from the upper case: adım 4, 3 resimden 2. SONOS ZP100 Network Card Replacement, Remove the screws from the upper case: adım 4, 3 resimden 3.
      • Using the precision tweezers to remove the sticker in the center of the top chassis.
      • Remove the three 35 mm Phillips screws and their washers that attach the top of the device to the bottom.
      • Even after removing the power plug, there may be dangerous charges on components in the device.
      FixBot'a Sor
      Yorum Ekle
    5. SONOS ZP100 Network Card Replacement: adım 5, 1 resimden 1.
      • Now turn the device over so you can remove the screws on the bottom.
      FixBot'a Sor
      Yorum Ekle
    6. SONOS ZP100 Network Card Replacement, Remove the rubber feet: adım 6, 3 resimden 1. SONOS ZP100 Network Card Replacement, Remove the rubber feet: adım 6, 3 resimden 2. SONOS ZP100 Network Card Replacement, Remove the rubber feet: adım 6, 3 resimden 3.
      • Use a spudger to remove the four stuck-on rubber feet. If necessary, use some heat (iOpener / hair dryer) to be able to loosen the feet better.
      FixBot'a Sor
      Yorum Ekle
    7. SONOS ZP100 Network Card Replacement, Remove the base plate: adım 7, 1 resimden 1.
      • Remove the four 10 mm Phillips screws in the countersinks.
      FixBot'a Sor
      Yorum Ekle
    8. SONOS ZP100 Network Card Replacement: adım 8, 2 resimden 1. SONOS ZP100 Network Card Replacement: adım 8, 2 resimden 2.
      • Lift the bottom lid up and set it aside. You will need it again.
      • The two WiFi antennas are located on the underside. These can cause injury or break.
      FixBot'a Sor
      Yorum Ekle
    9. SONOS ZP100 Network Card Replacement: adım 9, 1 resimden 1.
      • Remove the four 10 mm Phillips screws on the bottom.
      FixBot'a Sor
      Yorum Ekle
    10. SONOS ZP100 Network Card Replacement: adım 10, 2 resimden 1. SONOS ZP100 Network Card Replacement: adım 10, 2 resimden 2.
      • For a better stand and to avoid damaging the antenna, put the lower cover back on and turn the device over.
      FixBot'a Sor
      Yorum Ekle
    11. SONOS ZP100 Network Card Replacement, Remove the upper case: adım 11, 2 resimden 1. SONOS ZP100 Network Card Replacement, Remove the upper case: adım 11, 2 resimden 2.
      • Lift the top lid straight up on both sides.
      FixBot'a Sor
      Yorum Ekle
    12. SONOS ZP100 Network Card Replacement: adım 12, 3 resimden 1. SONOS ZP100 Network Card Replacement: adım 12, 3 resimden 2. SONOS ZP100 Network Card Replacement: adım 12, 3 resimden 3.
      • On the underside of the cover between the screws there are two heat conducting pads that transfer the heat generated from the amplifier-board to the case.
      • These Pads are very important, be careful not to lose them. They can either stick to the lid or in the device.
      FixBot'a Sor
      Yorum Ekle
    13. SONOS ZP100 Network Card Replacement, Remove the WiFi card: adım 13, 3 resimden 1. SONOS ZP100 Network Card Replacement, Remove the WiFi card: adım 13, 3 resimden 2. SONOS ZP100 Network Card Replacement, Remove the WiFi card: adım 13, 3 resimden 3.
      • Press both tabs outwards with our fingernails.
      • The card should pop up by itself.
      • Pull out the card in the direction of the connector and place it in front of the device.
      • The WiFi card is still connected to the device with two cables. Be careful not to damage or tear them down.
      FixBot'a Sor
      Yorum Ekle
    14. SONOS ZP100 Network Card Replacement: adım 14, 2 resimden 1. SONOS ZP100 Network Card Replacement: adım 14, 2 resimden 2.
      • Pull the 10-pin flat connector straight off towards the front of the device.
      • Make sure to pull out the entire plug including all cables.
      FixBot'a Sor
      Yorum Ekle
    15. SONOS ZP100 Network Card Replacement, Loosen the screws on the network card: adım 15, 1 resimden 1.
      • Remove the four 7 mm Phillips screws securing the network card to the case.
      FixBot'a Sor
      Yorum Ekle
    16. SONOS ZP100 Network Card Replacement, Lift the network card: adım 16, 3 resimden 1. SONOS ZP100 Network Card Replacement, Lift the network card: adım 16, 3 resimden 2. SONOS ZP100 Network Card Replacement, Lift the network card: adım 16, 3 resimden 3.
      • Lift the network card up at an angle and pull it together with the ethernet ports towards the front a little bit out of its fixing on the back.
      • Carefully turn the network card to the side.
      • The network card is still connected to the bottom with two cables. Be careful not to damage them.
      FixBot'a Sor
      Yorum Ekle
    17. SONOS ZP100 Network Card Replacement, Remove the ribbon cable: adım 17, 3 resimden 1. SONOS ZP100 Network Card Replacement, Remove the ribbon cable: adım 17, 3 resimden 2. SONOS ZP100 Network Card Replacement, Remove the ribbon cable: adım 17, 3 resimden 3.
      • Press the two tabs evenly away from the connector.
      • Gently pull the ribbon cable straight out of the connector toward the back.
      FixBot'a Sor
      Yorum Ekle
    18. SONOS ZP100 Network Card Replacement, Turn the network card to the side: adım 18, 1 resimden 1.
      • Now you can turn the network card further outwards so it is easier to get to the next connector.
      FixBot'a Sor
      Yorum Ekle
    19. SONOS ZP100 Network Card Replacement, Remove the power connection: adım 19, 3 resimden 1. SONOS ZP100 Network Card Replacement, Remove the power connection: adım 19, 3 resimden 2. SONOS ZP100 Network Card Replacement, Remove the power connection: adım 19, 3 resimden 3.
      • Remove the power cable from the network card. The plug is secured by a plastic tab. Push the nose away from the connector to pull it out.
      FixBot'a Sor
      Yorum Ekle
    20. SONOS ZP100 Network Card Replacement, Remove network card: adım 20, 1 resimden 1.
      • The network card is now completely separated and cut from the power supply.
      FixBot'a Sor
      Yorum Ekle
    21. SONOS ZP100 Network Card Replacement, Detach ribbon cable from Network Adapter board: adım 21, 3 resimden 1. SONOS ZP100 Network Card Replacement, Detach ribbon cable from Network Adapter board: adım 21, 3 resimden 2. SONOS ZP100 Network Card Replacement, Detach ribbon cable from Network Adapter board: adım 21, 3 resimden 3.
      • Press the two tabs evenly away from the socket.
      • Gently pull the ribbon cable to the Ethernet ports straight out of its socket on the network card.
      • Ribbon cables are very fragile handle with care.
      FixBot'a Sor
      Yorum Ekle
    22. SONOS ZP100 Network Card Replacement, Network card: adım 22, 2 resimden 1. SONOS ZP100 Network Card Replacement, Network card: adım 22, 2 resimden 2.
      • Front and back view of the network card.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Adrian
345 İtibar
1 Kılavuz yazıldı
Ekip
adrian büsselmann adrian büsselmann üyesi
Business
1 Üye
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 49
Her zaman: 2,366
