Giriş
The following guide details steps on how to reach your SONY Ericsson's motherboard. Once you reach the motherboard, you can identify issues the part may have.
Neye ihtiyacın var
Flick the two lock tabs into the unlocked positions by pushing each button forward.
Remove the two small rubber pieces that cover the lower screws.
Using a T-6 Torx wrench or screwdriver, remove all four of the small screws at the top and bottom corners on the back of the phones.
Now that the faceplate is off, use tweezers to separate the backplate from the inner manifold.
Bir başkası bu kılavuzu tamamladı.
