Ana içeriğe geç
SPÖKA IKEA Battery Replacement
Neye ihtiyacın var
  1. SPÖKA IKEA Battery Replacement, Battery replacement: adım 1, 1 resimden 1.
    • The most tricky part is to get the inner body out of the rubber shell.
    • I was supprised. The rubber can actually take some stretching
    • you end up with an egg shaped plastic body
  2. SPÖKA IKEA Battery Replacement: adım 2, 1 resimden 1.
    • Now we need to remove the bottom cap.
    • carefully bend the two hoocks inwards (e.g. with a small screwdriver) ad remove it
    • Now you can split the the body into two
  3. SPÖKA IKEA Battery Replacement: adım 3, 1 resimden 1.
    • you now can extract the battery pack.
    • on top you see the little switch to turn it on and off.
    • the LED are strapped with a cable tie around the battery
    • at the bottom lies the connector for recharging
  4. SPÖKA IKEA Battery Replacement: adım 4, 1 resimden 1.
    • remove the cable tie
    • remove the warapping of the battery pack
    • desolder the two cables from the pack
    • now it should look like the pack on the right
    • glue the new batteries together. - keep in mind, to alter the ends.
    • at the end you should have a new pack with (+) (-) (+) at one end and (-) (+) (-) at the other
  5. SPÖKA IKEA Battery Replacement: adım 5, 1 resimden 1.
    • this is the tricy part.
    • the new pack should be facing you with (+) (-) (+)
    • solder the right (+) to the (-) in the middle
    • Lolder the upper left (-) to the (+) in the middle
    • I used some old wire for it
    • Now solder the short black wire to the upper (-). It must be the only (-) with no connection yet
    • Solder the red long wire to the lower left (+). Also this must be the only (+) left without any connection
    • let it cool off
  6. SPÖKA IKEA Battery Replacement: adım 6, 1 resimden 1.
    • Use the cable tie to strap the LED back to the battery pack
    • isolate the open ends of the batterypack. It must not be able to create a short circuit. I used the hot glue. but also some thick rubber tape can do the job
    • put it back together in the shell
    • be aware to place the switch and the connector for recharging on the right places
  7. SPÖKA IKEA Battery Replacement: adım 7, 1 resimden 1.
    • Now its getting ugly again.
    • you have to put the shell back into the rubber
    • this could take a while
    • Be aware to put the connector on the right side, so you are able to recharge it again
  8. SPÖKA IKEA Battery Replacement: adım 8, 1 resimden 1.
    • Switch it back on and enjoy the bright light
    • Please remember that you altered a electric device.
    • never let your new spöka charge unattended and keep a good eye on it for short circuits
Sonuç
be aware that you altered an electric device!!!
If you do not know what you are doing... dont to it
2 farklı kişi bu kılavuzu tamamladı.
Colin
223 İtibar
1 Kılavuz yazıldı
Bir Yorum
This is a good writeup. One flaw is the old battery photo doesn’t show the markings — not everyone will want to hot-glue a NiMH battery pack from scratch, when you can purchase 4 for $10 on Amazon (from a baby monitor or cordless phone). These they have the advantage of using JST connectors (though you’d need to solder on a socket to take advantage of that).
ALSO - if you have the “fat Spoka” as I do, it uses 3 NiMH formed in a triangle (byd nimh battery h-aaa550X3) and those are IMPOSSIBLE to find so no retail option there — I probably will have to hot-glue the battery pack… :-)
scootz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 58
Her zaman: 15,082
