Ana içeriğe geç
SPOT X SPOTXB USB Port Replacement
Neye ihtiyacın var
  1. SPOT X SPOTXB USB Port Replacement, Back Cover: adım 1, 3 resimden 1. SPOT X SPOTXB USB Port Replacement, Back Cover: adım 1, 3 resimden 2. SPOT X SPOTXB USB Port Replacement, Back Cover: adım 1, 3 resimden 3.
    • Turn off the device completely by holding the power button for 10-20 seconds to force a shutdown.
  2. SPOT X SPOTXB USB Port Replacement: adım 2, 1 resimden 1.
    • Remove the seven 4.1 mm screws from the back of the device using a T4 Torx screwdriver.
  3. SPOT X SPOTXB USB Port Replacement: adım 3, 1 resimden 1.
    • Gently separate the back cover from the rest of the device.
  4. SPOT X SPOTXB USB Port Replacement, USB Port: adım 4, 1 resimden 1.
    • Remove the ten 2.9 mm screws from the motherboard using a T5 Torx screwdriver.
  5. SPOT X SPOTXB USB Port Replacement: adım 5, 1 resimden 1.
    • Use the Jimmy to gently open up the front frame.
  6. SPOT X SPOTXB USB Port Replacement: adım 6, 1 resimden 1.
    • Desolder the old USB port carefully using a soldering iron.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 196
