Ana içeriğe geç
SR405QM Battery Replacement
Neye ihtiyacın var
  1. SR405QM Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Gently place the instrument upside-down on a soft surface.
    • Locate the battery cavity cap and screws.
  2. SR405QM Battery Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #2 head screwdriver to unscrew both screws. Two #1 1mm long screws.
  3. SR405QM Battery Replacement: adım 3, 2 resimden 1. SR405QM Battery Replacement: adım 3, 2 resimden 2.
    • Remove the cap by lifting upwards to reveal the battery.
  4. SR405QM Battery Replacement: adım 4, 3 resimden 1. SR405QM Battery Replacement: adım 4, 3 resimden 2. SR405QM Battery Replacement: adım 4, 3 resimden 3.
    • Gently lift the battery from the cavity.
    • Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
Sonuç
To reassemble your device, follow these instructions in reverse order with a fresh battery.
2 farklı kişi bu kılavuzu tamamladı.
Chris Pittner
220 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-18, Forte Winter 2013 Cal Poly, Team 5-18, Forte Winter 2013 üyesi
CPSU-FORTE-W13S5G18
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 1,149
