Ana içeriğe geç
SVP 5800 Back Casing Replacement
Neye ihtiyacın var
  1. SVP 5800 Back Casing Replacement, Strap Hook: adım 1, 3 resimden 1. SVP 5800 Back Casing Replacement, Strap Hook: adım 1, 3 resimden 2. SVP 5800 Back Casing Replacement, Strap Hook: adım 1, 3 resimden 3.
    • Locate the two 3.5 mm screws on the side of the device.
    • Apply pressure to the PH J000 philips head screwdriver and turn in a counter clockwise motion until the screw becomes loose enough to pull out.
  2. SVP 5800 Back Casing Replacement, Front Casing: adım 2, 2 resimden 1. SVP 5800 Back Casing Replacement, Front Casing: adım 2, 2 resimden 2.
    • Once you have properly removed the strap hook, locate the two 3 mm screws located on the opposite side of the strap hook.
    • Refer to the prerequisite guide on removing the strap hook for instructions.
    • Place the PH J000 phillips head screwdriver on the head of screw; apply pressure and turn in a counter clockwise motion until screws come loose.
  3. SVP 5800 Back Casing Replacement: adım 3, 2 resimden 1. SVP 5800 Back Casing Replacement: adım 3, 2 resimden 2.
    • Place the plastic opening tool on the crack between the front and back casings.
    • Apply pressure by pulling down on the plastic opening tool to pry the case apart.
  4. SVP 5800 Back Casing Replacement: adım 4, 2 resimden 1. SVP 5800 Back Casing Replacement: adım 4, 2 resimden 2.
    • Wedge your fingers in the opening and slowly pull the front casing away from the bottom casing until it complete separates from the device.
    • Using too much force in this step can damage your device.
  5. SVP 5800 Back Casing Replacement, Top button Compartment: adım 5, 3 resimden 1. SVP 5800 Back Casing Replacement, Top button Compartment: adım 5, 3 resimden 2. SVP 5800 Back Casing Replacement, Top button Compartment: adım 5, 3 resimden 3.
    • Insert the flat end of wide metal spudger into the seam of the plastic buffer surrounding the buttons and pry it open.
  6. SVP 5800 Back Casing Replacement: adım 6, 3 resimden 1. SVP 5800 Back Casing Replacement: adım 6, 3 resimden 2. SVP 5800 Back Casing Replacement: adım 6, 3 resimden 3.
    • Use A #00 Phillips head screwdriver and turn counterclockwise to remove the four indicated screws.
    • Set the screws aside.
  7. SVP 5800 Back Casing Replacement: adım 7, 2 resimden 1. SVP 5800 Back Casing Replacement: adım 7, 2 resimden 2.
    • Apply pressure and turn counterclockwise to remove the indicated 2.5 mm screw.
  8. SVP 5800 Back Casing Replacement, Back Casing: adım 8, 2 resimden 1. SVP 5800 Back Casing Replacement, Back Casing: adım 8, 2 resimden 2.
    • Locate the 2 mm screw that is next to the battery compartment.
    • Using the PH J000 phillips head screwdriver, apply pressure to the screw head and turn in a counter clockwise motion until the screw is loose.
    • You do not have to completely remove the 2 mm screw. To prevent losing the screw, you may leave it loosely in its place.
  9. SVP 5800 Back Casing Replacement: adım 9, 3 resimden 1. SVP 5800 Back Casing Replacement: adım 9, 3 resimden 2. SVP 5800 Back Casing Replacement: adım 9, 3 resimden 3.
    • Slide the flat edge of the plastic opening tool between the inner casing and the back outer casing.
    • Push up on the plastic opening tool so that the back casing starts to lift from the inner casing.
    • Lifting the casing too far may result in damage. Lift the casing slowly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cheyenne Heinen
358 İtibar
3 adet Kılavuz yazıldı
Ekip
Marist, Team 1-3, Laflen Spring 2016 Marist, Team 1-3, Laflen Spring 2016 üyesi
MARS-LAFLEN-S16S1G3
2 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 597
