Ana içeriğe geç
SVP 5800 Front Casing Replacement
Neye ihtiyacın var
  1. SVP 5800 Front Casing Replacement, Strap Hook: adım 1, 3 resimden 1. SVP 5800 Front Casing Replacement, Strap Hook: adım 1, 3 resimden 2. SVP 5800 Front Casing Replacement, Strap Hook: adım 1, 3 resimden 3.
    • Locate the two 3.5 mm screws on the side of the device.
    • Apply pressure to the PH J000 philips head screwdriver and turn in a counter clockwise motion until the screw becomes loose enough to pull out.
  2. SVP 5800 Front Casing Replacement, Front Casing: adım 2, 2 resimden 1. SVP 5800 Front Casing Replacement, Front Casing: adım 2, 2 resimden 2.
    • Once you have properly removed the strap hook, locate the two 3 mm screws located on the opposite side of the strap hook.
    • Refer to the prerequisite guide on removing the strap hook for instructions.
    • Place the PH J000 phillips head screwdriver on the head of screw; apply pressure and turn in a counter clockwise motion until screws come loose.
  3. SVP 5800 Front Casing Replacement: adım 3, 2 resimden 1. SVP 5800 Front Casing Replacement: adım 3, 2 resimden 2.
    • Place the plastic opening tool on the crack between the front and back casings.
    • Apply pressure by pulling down on the plastic opening tool to pry the case apart.
  4. SVP 5800 Front Casing Replacement: adım 4, 2 resimden 1. SVP 5800 Front Casing Replacement: adım 4, 2 resimden 2.
    • Wedge your fingers in the opening and slowly pull the front casing away from the bottom casing until it complete separates from the device.
    • Using too much force in this step can damage your device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cheyenne Heinen
358 İtibar
3 adet Kılavuz yazıldı
Ekip
Marist, Team 1-3, Laflen Spring 2016 Marist, Team 1-3, Laflen Spring 2016 üyesi
MARS-LAFLEN-S16S1G3
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 319
