Ana içeriğe geç
Saab 9-3 Ignition Switch Module (ISM) Replacement
Neye ihtiyacın var
    1. Saab 9-3 Ignition Switch Module (ISM) Replacement, The starting point: adım 1, 1 resimden 1.
      • Our starting point: The center console with the ignition switch in the middle
      FixBot'a Sor
      Yorum Ekle
    2. Saab 9-3 Ignition Switch Module (ISM) Replacement, The tool: adım 2, 1 resimden 1.
      • This is the screwdriver bit used to remove all the screws.
      FixBot'a Sor
      Yorum Ekle
    3. Saab 9-3 Ignition Switch Module (ISM) Replacement, The ISM (Ignition Switch Module): adım 3, 1 resimden 1.
      • This is the item we need to replace
      FixBot'a Sor
      Yorum Ekle
    4. Saab 9-3 Ignition Switch Module (ISM) Replacement, Front side panels: adım 4, 1 resimden 1.
      • Step one is to remove the front side panels. There is a single (covered) screw in the footwell on each side that can be removed, and the panel slides rearwards, down and out.
      FixBot'a Sor
      Yorum Ekle
    5. Saab 9-3 Ignition Switch Module (ISM) Replacement, Panel screw: adım 5, 1 resimden 1.
      • Unscrew and remove this screw
      FixBot'a Sor
      Yorum Ekle
    6. Saab 9-3 Ignition Switch Module (ISM) Replacement, Front side panel comes off: adım 6, 1 resimden 1.
      • The panel can now come off.
      FixBot'a Sor
      Yorum Ekle
    7. Saab 9-3 Ignition Switch Module (ISM) Replacement, Rear cover: adım 7, 1 resimden 1.
      • Rear cover is removed next.
      FixBot'a Sor
      Yorum Ekle
    8. Saab 9-3 Ignition Switch Module (ISM) Replacement, Remove rear panel: adım 8, 1 resimden 1.
      • Next, locate the rear cover visible from the back seats, between the two front seats. Pull it sharply to the rear, and remove.
      FixBot'a Sor
      Yorum Ekle
    9. Saab 9-3 Ignition Switch Module (ISM) Replacement, Rear side panels: adım 9, 1 resimden 1.
      • The rear side panels in front of the rear cover are now easily accessible and can be removed.
      FixBot'a Sor
      Yorum Ekle
    10. Saab 9-3 Ignition Switch Module (ISM) Replacement, Rubber mat in front of gear lever: adım 10, 1 resimden 1.
      • Next, remove the rubber mat in front of the gear lever.
      FixBot'a Sor
      Yorum Ekle
    11. Saab 9-3 Ignition Switch Module (ISM) Replacement, Gear lever surround trim: adım 11, 1 resimden 1.
      • The (shiny) gear lever surround trim can now be prized off, starting at the rear, and removed.
      FixBot'a Sor
      Yorum Ekle
    12. Saab 9-3 Ignition Switch Module (ISM) Replacement, Retaining frame holding screw: adım 12, 1 resimden 1.
      • Removing the gear lever surround trim exposes a single screw holding a retaining frame underneath the gear change mechanism.
      FixBot'a Sor
      Yorum Ekle
    13. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 13, 1 resimden 1.
      • Unscrew the retaining screw
      FixBot'a Sor
      Yorum Ekle
    14. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 14, 1 resimden 1.
      • Remove the retaining frame
      FixBot'a Sor
      Yorum Ekle
    15. Saab 9-3 Ignition Switch Module (ISM) Replacement, Hand brake cover: adım 15, 1 resimden 1.
      • Slide out horizontally the protective plastic cover underneath the hand brake.
      FixBot'a Sor
      Yorum Ekle
    16. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 16, 1 resimden 1.
      • This exposes a single screw. Remove this.
      FixBot'a Sor
      Yorum Ekle
    17. Saab 9-3 Ignition Switch Module (ISM) Replacement, CD holder: adım 17, 1 resimden 1.
      • On the other side, remove the CD holder top cover,
      FixBot'a Sor
      Yorum Ekle
    18. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 18, 1 resimden 1.
      • unscrew the two screws inside,
      FixBot'a Sor
      Yorum Ekle
    19. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 19, 1 resimden 1.
      • and remove the CD holder itself. This exposes another single screw. Remove this.
      FixBot'a Sor
      Yorum Ekle
    20. Saab 9-3 Ignition Switch Module (ISM) Replacement, Storage unit: adım 20, 1 resimden 1.
      • Remove the bottom rubber cover in the centre console storage unit.
      FixBot'a Sor
      Yorum Ekle
    21. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 21, 1 resimden 1.
      • This exposes two screws that need removing.
      FixBot'a Sor
      Yorum Ekle
    22. Saab 9-3 Ignition Switch Module (ISM) Replacement, Drinks holder: adım 22, 1 resimden 1.
      • The drinks holder has another rubber mat.
      FixBot'a Sor
      Yorum Ekle
    23. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 23, 1 resimden 1.
      • There are no screws underneath, but this is a good opportunity to remove it and clean it separately.
      FixBot'a Sor
      Yorum Ekle
    24. Saab 9-3 Ignition Switch Module (ISM) Replacement, Air duct: adım 24, 1 resimden 1.
      • Underneath the air vent controlling air flow to the passengers from the center console sits a square duct.
      FixBot'a Sor
      Yorum Ekle
    25. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 25, 1 resimden 1.
      • The Haynes manual suggests pulling this out next, and although it is possible to do so, it requires force, and is much easier to do later when all other fixings have been removed.
      FixBot'a Sor
      Yorum Ekle
    26. Saab 9-3 Ignition Switch Module (ISM) Replacement, Cable bundles: adım 26, 1 resimden 1.
      • There are two cable bundles connected to the center console from the rest of the car. One is connected via a large, square plug with a red tab.
      FixBot'a Sor
      Yorum Ekle
    27. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 27, 1 resimden 1.
      • Push a screwdriver inside the red tab and pull, and the connector splits neatly apart.
      FixBot'a Sor
      Yorum Ekle
    28. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 28, 1 resimden 1.
      • The other is an earth connector near the rear of the console. This can easily be pulled away.
      FixBot'a Sor
      Yorum Ekle
    29. Saab 9-3 Ignition Switch Module (ISM) Replacement, Retaining screws in front of the gear lever: adım 29, 1 resimden 1.
      • Remove two screws located in front of the gear lever.
      FixBot'a Sor
      Yorum Ekle
    30. Saab 9-3 Ignition Switch Module (ISM) Replacement, Horizontal retainer screws -- a fiddle to get out!!: adım 30, 1 resimden 1.
      • The next bit is a bit fiddly to get to: There are two screws going horizontally, one underneath the handbrake,
      FixBot'a Sor
      Yorum Ekle
    31. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 31, 1 resimden 1.
      • the other on the CD holder side. These need to be removed. There is limited workspace. Use a separate loose screwdriver bit, and a spanner to twist it.
      FixBot'a Sor
      Yorum Ekle
    32. Saab 9-3 Ignition Switch Module (ISM) Replacement, Remove center console: adım 32, 3 resimden 1. Saab 9-3 Ignition Switch Module (ISM) Replacement, Remove center console: adım 32, 3 resimden 2. Saab 9-3 Ignition Switch Module (ISM) Replacement, Remove center console: adım 32, 3 resimden 3.
      • The center console is now loose, and can be puller backwards and upwards, and removed from the car.
      FixBot'a Sor
      Yorum Ekle
    33. Saab 9-3 Ignition Switch Module (ISM) Replacement, ISM switch: adım 33, 3 resimden 1. Saab 9-3 Ignition Switch Module (ISM) Replacement, ISM switch: adım 33, 3 resimden 2. Saab 9-3 Ignition Switch Module (ISM) Replacement, ISM switch: adım 33, 3 resimden 3.
      • Tip the centre console upside down and locate the ISM ignition switch.There are four spring clips holding it in place. Use a screwdriver to compress each clip in turn, whilst pushing the switch out of its socket.
      FixBot'a Sor
      Yorum Ekle
    34. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 34, 3 resimden 1. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 34, 3 resimden 2. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 34, 3 resimden 3.
      • The switch is connected to a cable via a connector. Locate the torque lever and twist this to release the connector.
      FixBot'a Sor
      Yorum Ekle
    35. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 35, 2 resimden 1. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 35, 2 resimden 2.
      • You now have the ISM in your hand. Swap this with a replacement unit. Mine cost £126,00 new from eBay. Clip it in the same spot, and connect the cable again.
      FixBot'a Sor
      Yorum Ekle
      • The rest of the procedure is doing the dismantling in reverse. However, this is the best order that I found (choosing the wrong order once or twice):
      FixBot'a Sor
      Yorum Ekle
    36. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 37, 1 resimden 1.
      • The square air conditioning duct goes in first. The console goes in next. It is a bit awkward to riggle past all the lugs, screws, tabs and cables, but just persevere. Once in, fit all the screws holding it in place, including the awkward ones.
      FixBot'a Sor
      Yorum Ekle
    37. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 38, 3 resimden 1. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 38, 3 resimden 2. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 38, 3 resimden 3.
      • Connect the two cables. The earth connector is push-on, and the square plug self-locks when the red tab is pushed.
      FixBot'a Sor
      Yorum Ekle
      • Next, fit the retaining frame underneath the gear lever, all screws around it, then the shiny gear lever surround trim, and finally the rubber mat in front of it. Fit the side rear panels, then the front panels (fasten them with the single screw), then the rear cover.
      FixBot'a Sor
      Yorum Ekle
    38. Saab 9-3 Ignition Switch Module (ISM) Replacement: adım 40, 1 resimden 1.
      • With all side panels in place, re-fit the screws around the gear lever and CD holder. Finally, slide the handbrake cover in place, and screw the CD holder in. All rubber mats put in place (you *did* clean them whilst you had the chance, right..?). You are done!
      FixBot'a Sor
      Yorum Ekle
      • Touch Wood, my car is now purring, with none of the issues I had before. Having heard quotes from around £1,000 upwards for a complete ISM / CIM refit, I am well pleased with the result.
      FixBot'a Sor
      Yorum Ekle
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Lars Erlandsen
1.403 İtibar
2 adet Kılavuz yazıldı
26Kılavuz Yorumları
And the key worked once plugged in and the battery is reconnected?
Michael Sullivan - Yanıt Paylaş
These are great instructions. I had the dreaded ‘steering lock malfunction’ warning message on my 9-3. Bought an ISM off eBay for £35 and had it fitted and working fine in 2 hours. Thanks so much for posting.
Mike - Yanıt Paylaş
Instructuctions spot on. In 1.5hrs I had the ISM out, cleaned and back in. And no more steering lock errors. !!!
gtsmail951 - Yanıt Paylaş
Does anyone have advice on how to replace the ignition switch on a 1998 9.3 automatic transmission Saab
davina gammon - Yanıt Paylaş
Most of these steps are not necessary at all, you can pull the ISM out from the side when you have removed the side panel, its tight but more than possible. This is very easy, 3h is a joke it takes 30 minutes at most!
Filip Andersson - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 18
Son 30 gün: 177
Her zaman: 37,916
