Giriş
The Minuto can be put into test mode very easily. It allows you to easily check many functions.
Turn off the machine at the power switch on the back.
With your left hand, press and hold the top left and bottom right buttons at the same time. On this model, it is the espresso and menu buttons.
Turn the power switch on the back back on with your other hand. Release the buttons and the machine is in test mode
The next screen is split again. On the left is the temperature of the heater, if you press the top left button, the heater will turn on and the temperature will increase. On the right you can check the grinder by pressing the top right button, key figures for the motor are displayed.
The next key press takes you back to the beginning. To exit test mode, turn the device off and on again using the power switch on the back.
Work the steps in reverse order to reassemble your device.
2 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
oldturkey03 dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
