Ana içeriğe geç
Saeco Royal Pump Replacement
Neye ihtiyacın var
  1. Saeco Royal Pump Replacement, Preparing: adım 1, 1 resimden 1.
    • Unplug!
    • Remove all attachments like water tank, brewing unit etc.
    • The pictures show a Royal Cappucino One Touch HD8930, but the opening procedure is similar to all models.
  2. Saeco Royal Pump Replacement, Top: adım 2, 2 resimden 1. Saeco Royal Pump Replacement, Top: adım 2, 2 resimden 2.
    • The coffeebean supply is fixed with two screws. Unscrew them and lift it off.
    • There is a black rubber lid under the bean hopper that you can easily lift off, leaving a large opening.
    • The adjuster of the grinder has to be solved. Mark the position or just take a picture. This type is fixed with a screw, others are only sticked together.
  3. Saeco Royal Pump Replacement, Rear side: adım 3, 1 resimden 1.
    • There are two screws to be turned out.
  4. Saeco Royal Pump Replacement, Front: adım 4, 3 resimden 1. Saeco Royal Pump Replacement, Front: adım 4, 3 resimden 2. Saeco Royal Pump Replacement, Front: adım 4, 3 resimden 3.
    • The screws are situated on the underneath of the cover. This type is held by four screws.
  5. Saeco Royal Pump Replacement, Lift cover off: adım 5, 2 resimden 1. Saeco Royal Pump Replacement, Lift cover off: adım 5, 2 resimden 2.
    • Now the cover can be raised: first grip on left and right rear side and lift about 10 cm (4 in). Sometimes the cover jams a little bit.
    • Solve the hoses which lead to the water tank. Perhaps you have to pull out some contacts, (e.g. the yellow-green protection lead), don´t forget to put them on again later.
    • The cover can be drawn aslant towards the front, sliding it over the hot water pipe.
    • Most repairs can be done with the cover being laid up partially , it must not be completely removed.
  6. Saeco Royal Pump Replacement, Pump: adım 6, 2 resimden 1. Saeco Royal Pump Replacement, Pump: adım 6, 2 resimden 2.
    • Here the pump viewed from above, a Ulka EX5 with 230V. The pump is stored in rubber pieces.
    • Pull the silicone hose off the rear elbow.
    • If not already done, remove the clamp on the pressure hose on the pressure relief valve. Then remove the pressure hose.
    • The pressure hose is sealed with two O-rings at the end. These will usually hang at the end. Replace them before re-assembling.
  7. Saeco Royal Pump Replacement: adım 7, 3 resimden 1. Saeco Royal Pump Replacement: adım 7, 3 resimden 2. Saeco Royal Pump Replacement: adım 7, 3 resimden 3.
    • In the first picture, the pump has already been removed. The red marking shows the catch that holds the rubber molded part. You can easily pull it out when the catch is pressed down.
    • Pull the angled molded rubber parts out of their spots on the floor.
    • Lift the pump with the rubber moldings out of the machine.
    • When reassembling, make sure that the molded rubber part is correctly attached.
  8. Saeco Royal Pump Replacement, Replacing the pump: adım 8, 1 resimden 1.
    • Unscrew the pressure relief valve with two wrenches SW 10 and 13.
    • Only the pump itself as well as the relief valve will remain.
    • If you want to replace the pump, you'll have to transfer the pressure relief valve to the new pump. You should also service your valve while you're at it.
Sonuç
Work through the steps in reverse order to reassemble your device.
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
VauWeh
201.178 İtibar
246 adet Kılavuz yazıldı
Ekip
Repair is War on Entropy Repair is War on Entropy üyesi
Community
24 Üyeler
1.096 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 48
Her zaman: 3,231
