Ana içeriğe geç
Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement
Neye ihtiyacın var
  1. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Battery: adım 1, 2 resimden 1. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Battery: adım 1, 2 resimden 2.
    • Remove all external power and turn off the tablet.
    • Insert a plastic opening tool between the screen and rear casing.
    • Pry the screen and rear casing apart.
  2. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: adım 2, 3 resimden 1. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: adım 2, 3 resimden 2. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: adım 2, 3 resimden 3.
    • Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
    • Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
  3. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: adım 3, 3 resimden 1. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: adım 3, 3 resimden 2. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: adım 3, 3 resimden 3.
    • Remove the ten 4mm Phillips #000 screws from the battery.
    • Use a plastic opening tool to pry up the battery.
    • Remove the battery.
  4. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Home Button: adım 4, 2 resimden 1. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Home Button: adım 4, 2 resimden 2.
    • Remove the green protective tape from the three ZIF connectors on the motherboard.
    • Pull the ribbon cables out of their sockets.
  5. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: adım 5, 2 resimden 1. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: adım 5, 2 resimden 2.
    • Remove the six 4mm Phillips #000 screws from the motherboard.
    • Remove the motherboard.
  6. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: adım 6, 2 resimden 1. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: adım 6, 2 resimden 2.
    • Insert a plastic opening tool between the screen and bezel.
    • Slide the plastic opening tool around the perimeter while applying a prying motion.
    • Remove the screen from the display.
    • Applying heat may be needed to loosed the glue.
  7. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: adım 7, 2 resimden 1. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: adım 7, 2 resimden 2.
    • Locate the Home button on the front of the panel and carefully lift the gold ribbon surrounding it from RIGHT to LEFT.
  8. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: adım 8, 1 resimden 1.
    • Using your Phillips #000 screwdriver Remove the two 4mm Phillips #000 screws from the home button.
  9. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: adım 9, 1 resimden 1.
    • Remove the home button by sliding it to the left or right while pulling up.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Guneet Bawa
688 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G5, Liner Spring 2018 UW Tacoma, Team S1-G5, Liner Spring 2018 üyesi
UWT-LINER-S18S1G5
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 2,012
