Ana içeriğe geç
Samsung 27E510C NAV Button Replacement
Neye ihtiyacın var
  1. Samsung 27E510C  NAV Button Replacement, Back Panel: adım 1, 3 resimden 1. Samsung 27E510C  NAV Button Replacement, Back Panel: adım 1, 3 resimden 2. Samsung 27E510C  NAV Button Replacement, Back Panel: adım 1, 3 resimden 3.
    • Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
    • The screw alone with the ports is a different size than the rest, its length is 12mm.
  2. Samsung 27E510C  NAV Button Replacement: adım 2, 2 resimden 1. Samsung 27E510C  NAV Button Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Heavy-Duty Spudger
    • Insert the heavy duty spudger in between the monitors back panel and its frame.
    • Use the heavy duty spudger to pry open the back panel.
    • Over aggressive prying could break the tabs holding the back panel in place.
  3. Samsung 27E510C  NAV Button Replacement, Rear navigation button: adım 3, 1 resimden 1.
    • Carefully remove the tape holding down the connector wire.
    • You will need to re-attach the tape upon reassembly.
  4. Samsung 27E510C  NAV Button Replacement: adım 4, 1 resimden 1.
    • Disconnect the navigation button from the motherboard by holding down the thumb tab and pulling its connector out.
  5. Samsung 27E510C  NAV Button Replacement: adım 5, 2 resimden 1. Samsung 27E510C  NAV Button Replacement: adım 5, 2 resimden 2.
    • Remove the navigation buttons connector wire from the monitors body tab.
  6. Samsung 27E510C  NAV Button Replacement: adım 6, 1 resimden 1.
    • With one thumb, hold down the tab on the bottom of the navigation buttons base.
    • While holding the tab down, lift the base of the navigation button with your other hand.
  7. Samsung 27E510C  NAV Button Replacement: adım 7, 3 resimden 1. Samsung 27E510C  NAV Button Replacement: adım 7, 3 resimden 2. Samsung 27E510C  NAV Button Replacement: adım 7, 3 resimden 3.
    • Remove the connector wire from the defective navigation button by first gripping its connectors thumb tab.
    • While gripping the thumb tab, pull the connector from the base of the navigation button.
    • You can save the connector wire since it may not be defective.
Sonuç
giggythore
376 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 29
Her zaman: 830
