Ana içeriğe geç
Samsung 27E510C Back Panel Replacement
Neye ihtiyacın var
  1. Samsung 27E510C Back Panel Replacement, Back Panel: adım 1, 3 resimden 1. Samsung 27E510C Back Panel Replacement, Back Panel: adım 1, 3 resimden 2. Samsung 27E510C Back Panel Replacement, Back Panel: adım 1, 3 resimden 3.
    • Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
    • The screw alone with the ports is a different size than the rest, its length is 12mm.
  2. Samsung 27E510C Back Panel Replacement: adım 2, 2 resimden 1. Samsung 27E510C Back Panel Replacement: adım 2, 2 resimden 2.
    • Insert the heavy duty spudger in between the monitors back panel and its frame.
    • Use the heavy duty spudger to pry open the back panel.
    • Over aggressive prying could break the tabs holding the back panel in place.
Sonuç
giggythore
366 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S9-G1, Banghart Fall 2017 Cal Poly, Team S9-G1, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S9G1
6 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 25
Her zaman: 1,311
