Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the back panel of the device by taking out the seven screws on the back panel of the device. Four of the screws are under the rubber feet so they will need to be removed.  To remove the feet, pry them off with the spudger.
    • Remove the back panel of the device by taking out the seven screws on the back panel of the device.
    • Four of the screws are under the rubber feet so they will need to be removed. To remove the feet, pry them off with the spudger.
  2. Dizüstü Bilgisayar Bataryaları
    An easy fix for a big power boost.
    Hemen Alışveriş Yapın
  3. Remove the seven screws that are holding in the battery.  They can be seen circled in the picture. When unscrewed, lift the battery.  There will be a cable connected to the battery.  Detach this cable from the board and remove the battery. Attach the replacement battery cable to the board and reassemble.  It can be seen highlighted in picture 2.
    • Remove the seven screws that are holding in the battery. They can be seen circled in the picture.
    • When unscrewed, lift the battery. There will be a cable connected to the battery. Detach this cable from the board and remove the battery.
    • Attach the replacement battery cable to the board and reassemble. It can be seen highlighted in picture 2.
    • *Note: When reinserting the battery it is easier to put in the long end first and then dropping the other side in.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Garrett Kissinger
692 İtibar
5 adet Kılavuz yazıldı
Takım
Michigan Tech, Team 1-2, Lauer Spring 2014 Michigan Tech, Team 1-2, Lauer Spring 2014 üyesi
MTU-LAUER-S14S1G2
3 Üyeler
Bir Yorum
Samsung 500C ChromeBook Battery where to buy?
Uzi Naveh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 5
Son 30 Gün: 17
Her zaman: 2,332
