Parçalar
Hiçbir parçaya gerek yok.
  1. Remove the back panel of the device by taking out the seven screws on the back panel of the device. Four of the screws are under the rubber feet so they will need to be removed.  To remove the feet, pry them off with the spudger.
    • Remove the back panel of the device by taking out the seven screws on the back panel of the device.
    • Four of the screws are under the rubber feet so they will need to be removed. To remove the feet, pry them off with the spudger.
  2. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Locate the wireless card.  It is shown highlighted in picture one. Detach the black and white cords connected to the wireless card and unscrew the screw holding in the card.  They are shown highlighted in picture two. Pull the card out of its slot and insert the new card.  Reattach the wires and reassemble the device.  Note: the white wire connects to the terminal closer to the screw and the black to the other terminal.
    • Locate the wireless card. It is shown highlighted in picture one.
    • Detach the black and white cords connected to the wireless card and unscrew the screw holding in the card. They are shown highlighted in picture two.
    • Pull the card out of its slot and insert the new card. Reattach the wires and reassemble the device. Note: the white wire connects to the terminal closer to the screw and the black to the other terminal.
Sonuç
Garrett Kissinger
692 İtibar
5 adet Kılavuz yazıldı
Takım
Michigan Tech, Team 1-2, Lauer Spring 2014 Michigan Tech, Team 1-2, Lauer Spring 2014 üyesi
MTU-LAUER-S14S1G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 3
Son 30 Gün: 22
Her zaman: 1,333
