Ana içeriğe geç
Samsung A3 2016 Model - A310F Display / LCD Replacement
Neye ihtiyacın var
  1. Samsung A3 2016 Model - A310F Display / LCD Replacement, Display / LCD: adım 1, 1 resimden 1.
    • Remove the SIM tray from the phone.
    FixBot'a Sor
  2. Samsung A3 2016 Model - A310F Display / LCD Replacement, Removing the battery cover: adım 2, 1 resimden 1.
    • Use a heat gun or iOpener to heat the back of the phone.
    • Insert a spudger or thin bladed tool between the batery cover and frame.
    • Slide all the way around to release the adhesive holding the cover.
    • The battery cover is also glass and can break if too much pressure is applied when removeing.
    FixBot'a Sor
  3. Samsung A3 2016 Model - A310F Display / LCD Replacement: adım 3, 2 resimden 1. Samsung A3 2016 Model - A310F Display / LCD Replacement: adım 3, 2 resimden 2.
    • Remove all 16 screws from the housing
    FixBot'a Sor
  4. Samsung A3 2016 Model - A310F Display / LCD Replacement: adım 4, 1 resimden 1.
    • Hold the edge of the housing and push on the battery to release the display and mainboard from the housing.
    • You may need to go around the edge of the glass with a pick to remove any remaining adhesive
    FixBot'a Sor
  5. Samsung A3 2016 Model - A310F Display / LCD Replacement: adım 5, 1 resimden 1.
    • Remove the Philips screw securing the mainboard.
    • Remove the cable attached to the mainboard
    • Disconnect the display and camera connectors from the mainboard
    FixBot'a Sor
  6. Samsung A3 2016 Model - A310F Display / LCD Replacement: adım 6, 2 resimden 1. Samsung A3 2016 Model - A310F Display / LCD Replacement: adım 6, 2 resimden 2.
    • Disconnect the daughter board from the mainboard
    FixBot'a Sor
  7. Samsung A3 2016 Model - A310F Display / LCD Replacement: adım 7, 1 resimden 1.
    • Using a heatgun, heat the front of the display.
    • Use a spudger or pick to work the display and LCD free from the plastic housing. NOTE: The LCD is also glued to the frame and will probably break as well.
    • When mounting the new display, the display cable slots through a gap in the plastic frame and attaches to the mainboard.
    FixBot'a Sor
  8. Samsung A3 2016 Model - A310F Display / LCD Replacement: adım 8, 3 resimden 1. Samsung A3 2016 Model - A310F Display / LCD Replacement: adım 8, 3 resimden 2. Samsung A3 2016 Model - A310F Display / LCD Replacement: adım 8, 3 resimden 3.
    • Reattach the daughter board connector to the mainboard.
    • When re-inserting the mainboard, use a plastic spudger to push the battery pins in so the mainboard sits properly in the frame and the pins make a good contact with the battery.
    • Re-connect the display connector, camera and cable to the mainboard.
    • Screw the mainboard to the frame
    FixBot'a Sor
  9. Samsung A3 2016 Model - A310F Display / LCD Replacement: adım 9, 1 resimden 1.
    • Turn the phone on and test the display before removing the adhesive on the back of the display.
    • If everything works, remove the adhesive and attach the display to the plastic frame.
    • Push the display into the metal housing so it fits snugly.
    FixBot'a Sor
  10. Samsung A3 2016 Model - A310F Display / LCD Replacement: adım 10, 2 resimden 1. Samsung A3 2016 Model - A310F Display / LCD Replacement: adım 10, 2 resimden 2.
    • Replace the 16 screws that were removed in step 3.
    • Replace the battery cover and you are done.
    FixBot'a Sor
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Harvey
6.435 İtibar
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 67
Her zaman: 4,264
