Ana içeriğe geç
Samsung ASV09PSBAN Circuit Board Replacement
Neye ihtiyacın var
  1. Samsung ASV09PSBAN Circuit Board Replacement, Circuit Board: adım 1, 1 resimden 1.
    • Turn off the power from the circuit breaker.
  2. Samsung ASV09PSBAN Circuit Board Replacement: adım 2, 3 resimden 1. Samsung ASV09PSBAN Circuit Board Replacement: adım 2, 3 resimden 2. Samsung ASV09PSBAN Circuit Board Replacement: adım 2, 3 resimden 3.
    • Carefully remove the front grille panel by placing your hands at the top of the air intake cover.
  3. Samsung ASV09PSBAN Circuit Board Replacement: adım 3, 1 resimden 1.
    • Use your hands to remove the air filters.
    • Clean the air intake screen with a vacuum if necessary.
  4. Samsung ASV09PSBAN Circuit Board Replacement: adım 4, 3 resimden 1. Samsung ASV09PSBAN Circuit Board Replacement: adım 4, 3 resimden 2. Samsung ASV09PSBAN Circuit Board Replacement: adım 4, 3 resimden 3.
    • Remove the screw from the small panel on the right side.
    • Remove the cover.
  5. Samsung ASV09PSBAN Circuit Board Replacement: adım 5, 2 resimden 1. Samsung ASV09PSBAN Circuit Board Replacement: adım 5, 2 resimden 2.
    • Disconnect the black wire from the unit.
  6. Samsung ASV09PSBAN Circuit Board Replacement: adım 6, 3 resimden 1. Samsung ASV09PSBAN Circuit Board Replacement: adım 6, 3 resimden 2. Samsung ASV09PSBAN Circuit Board Replacement: adım 6, 3 resimden 3.
    • Disconnect the two parts of the white wire.
  7. Samsung ASV09PSBAN Circuit Board Replacement: adım 7, 3 resimden 1. Samsung ASV09PSBAN Circuit Board Replacement: adım 7, 3 resimden 2. Samsung ASV09PSBAN Circuit Board Replacement: adım 7, 3 resimden 3.
    • Remove two screws from each side of the front panel.
  8. Samsung ASV09PSBAN Circuit Board Replacement: adım 8, 3 resimden 1. Samsung ASV09PSBAN Circuit Board Replacement: adım 8, 3 resimden 2. Samsung ASV09PSBAN Circuit Board Replacement: adım 8, 3 resimden 3.
    • Completely remove the front panel.
    • If you can not remove it easily, use a spudger to carefully pry it open.
  9. Samsung ASV09PSBAN Circuit Board Replacement: adım 9, 3 resimden 1. Samsung ASV09PSBAN Circuit Board Replacement: adım 9, 3 resimden 2. Samsung ASV09PSBAN Circuit Board Replacement: adım 9, 3 resimden 3.
    • Remove the old circuit board from the three notches holding it in place.
    • Thread the bundled white wire through the slot and remove the circuit board completely from the unit.
    • Install a new circuit board.
  10. Samsung ASV09PSBAN Circuit Board Replacement: adım 10, 2 resimden 1. Samsung ASV09PSBAN Circuit Board Replacement: adım 10, 2 resimden 2.
    • Reinstall the front panel.
    • Replace the two screws on each side of the front panel.
  11. Samsung ASV09PSBAN Circuit Board Replacement: adım 11, 3 resimden 1. Samsung ASV09PSBAN Circuit Board Replacement: adım 11, 3 resimden 2. Samsung ASV09PSBAN Circuit Board Replacement: adım 11, 3 resimden 3.
    • Reconnect the white wires.
    • Thread the black wire through the slots.
  12. Samsung ASV09PSBAN Circuit Board Replacement: adım 12, 1 resimden 1.
    • Reinstall the small cover.
  13. Samsung ASV09PSBAN Circuit Board Replacement: adım 13, 2 resimden 1. Samsung ASV09PSBAN Circuit Board Replacement: adım 13, 2 resimden 2.
    • Reinstall the filter.
  14. Samsung ASV09PSBAN Circuit Board Replacement: adım 14, 2 resimden 1. Samsung ASV09PSBAN Circuit Board Replacement: adım 14, 2 resimden 2.
    • Restore the power to check if the unit is functioning.
  15. Samsung ASV09PSBAN Circuit Board Replacement: adım 15, 3 resimden 1. Samsung ASV09PSBAN Circuit Board Replacement: adım 15, 3 resimden 2. Samsung ASV09PSBAN Circuit Board Replacement: adım 15, 3 resimden 3.
    • If the unit is functioning, turn the fan off, and reinstall the front grille panel.
    • At the end, you can turn it on again.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Jenny
269 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
I am having problem like different way, if I set temperature from 23'C to 17'C than only outdoor unit (compressor unit) start working. Even though it's started, but I feel the temperature like 29 'C only. What will be the problem? Suggest me..
Kishore Kumar S - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 13
Son 30 gün: 75
Her zaman: 3,407
