Ana içeriğe geç
Samsung ATIV Book 4 Battery Replacement
Neye ihtiyacın var
  1. Samsung ATIV Book 4 Battery Replacement, Battery: adım 1, 2 resimden 1. Samsung ATIV Book 4 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Place the computer upside down.
    • Remove 2 rubber pads, by prying up on them.
    • There may be adhesive holding them down. If this is the case, the plastic opening tool may be needed to remove them.
    • Remove the seven 6.5mm screws on exterior of computer.
  2. Samsung ATIV Book 4 Battery Replacement: adım 2, 2 resimden 1. Samsung ATIV Book 4 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the panel by sliding it down and lifting it away from the computer.
    • Remove the four 4.4mm screws that are underneath the panel.
    • Remove the two 6.5mm screws that were underneath the rubber pads.
  3. Samsung ATIV Book 4 Battery Replacement: adım 3, 2 resimden 1. Samsung ATIV Book 4 Battery Replacement: adım 3, 2 resimden 2.
    • Using the plastic opening tool, pry plastic panel away from computer.
    • Start prying at one point and work your way around the entire computer until panel is free come computer.
    • Remove the panel from computer, once all tabs are broken free.
  4. Samsung ATIV Book 4 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the four 3.5mm screws holding the battery.
    • Peel back the tape securing the wires to the battery.
    • Lift and remove the battery from its location.
    • Don't pull/tear the wires connected to battery harness.
  5. Samsung ATIV Book 4 Battery Replacement: adım 5, 1 resimden 1.
    • Disconnect the battery harness from computer.
    • Completely remove the battery and replace it.
  6. Samsung ATIV Book 4 Battery Replacement: adım 6, 1 resimden 1.
    • Plug battery harness back in.
    • Assure the wires are pointed up (towards you) then plugging back in, as shown.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Chad
437 İtibar
2 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-7, Lauer Spring 2015 Michigan Tech, Team 1-7, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G7
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 9,674
