Ana içeriğe geç
Samsung ATIV Book 4 Screen Replacement
Neye ihtiyacın var
  1. Samsung ATIV Book 4 Screen Replacement, Screen: adım 1, 2 resimden 1. Samsung ATIV Book 4 Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Be sure the computer is off, and open the computer so that the screen is showing.
    • Use the plastic opening tool and pry away the casing surrounding the screen. Remove the casing entirely.
  2. Samsung ATIV Book 4 Screen Replacement: adım 2, 1 resimden 1.
    • Remove the four 3.5mm screws securing the screen.
    • Tilt the screen back before removing the screws, there is a possibility it could fall and damage your keyboard or the ribbon cable connected to it.
  3. Samsung ATIV Book 4 Screen Replacement: adım 3, 1 resimden 1.
    • Place the screen gently on the keyboard.
  4. Samsung ATIV Book 4 Screen Replacement: adım 4, 1 resimden 1.
    • Remove the ribbon cable from the screen.
    • Remove and replace the screen.
Sonuç
Daniel
342 İtibar
3 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-7, Lauer Spring 2015 Michigan Tech, Team 1-7, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G7
2 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Where do you buy the replacement screen for the ATIV Book 4? Thanks!
RMS015 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 3,356
