Giriş
The graphics screen is nested behind the capacitive touchscreen. Therefore, in order to replace the graphics-screen it is mandatory to remove the capacitive touch screen first. This guide will show the user the proper way remove the graphics-screen.
Neye ihtiyacın var
Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
Disconnect the databus from the motherboard as seen in the lower left of the picture
Disconnect the white and black wire from the graphics card as seen in the middle of the photo. (Note: These two wires are connected to the motherboard by means of snap-in male-female copper connectors, meaning they can be disconnected by un-snapping the connectors.
Remove the six 3 mm screws using the Phillips #000 screwdriver.
Unhook the ribbon connection.
Remove the screen.
Important Note: When re-assembling the screen assembly, additional adhesive glue may be needed to adhere the graphic-screen, capacitive touch-screen and screen cover back onto the original assembly.
