Ana içeriğe geç
Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement
Neye ihtiyacın var
  1. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement, Backplate: adım 1, 2 resimden 1. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement, Backplate: adım 1, 2 resimden 2.
    • Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
  2. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the backplate.
  3. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the six 5mm screws that hold the battery by using the Phillips #0 screwdriver.
  4. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery from the motherboard and remove the battery.
  5. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement, Speaker: adım 5, 1 resimden 1.
    • There are two speakers which are found on the lower left and right side of the laptop, beside the battery.
  6. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement: adım 6, 3 resimden 1. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement: adım 6, 3 resimden 2. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement: adım 6, 3 resimden 3.
    • Remove the screws of the motherboard to disconnect the motherboard from the speakers using a Phillips #0 screwdriver.
  7. Samsung ATIV Book 7 NP740U3E-K01UB Speaker Replacement: adım 7, 1 resimden 1.
    • Remove the 4 mm screw with the Phillips #000 screwdriver and remove the speaker.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alexander Nwonye
127 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G5, Simcock Spring 2019 UMass Dartmouth, Team S2-G5, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S2G5
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 160
