Ana içeriğe geç
Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement
Neye ihtiyacın var
  1. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement, Backplate: adım 1, 2 resimden 1. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement, Backplate: adım 1, 2 resimden 2.
    • Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
  2. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement: adım 2, 1 resimden 1.
    • Remove the backplate.
  3. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the six 5mm screws that hold the battery by using the Phillips #0 screwdriver.
  4. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery from the motherboard and remove the battery.
  5. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement, Track Pad: adım 5, 1 resimden 1.
    • Disconnect the track pad from the motherboard.
  6. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement: adım 6, 2 resimden 1. Samsung ATIV Book 7 NP740U3E-K01UB Track Pad Replacement: adım 6, 2 resimden 2.
    • Peel the tape on the track pad back.
    • Unscrew the five 2mm screws with the Phillips #0 screwdriver.
    • Rotate the track pad out of the case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jonathan Robidoux
196 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G5, Simcock Spring 2019 UMass Dartmouth, Team S2-G5, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S2G5
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 230
