Ana içeriğe geç
Samsung ATIV Book 9 Lite Audio Port Replacement
Neye ihtiyacın var
  1. Samsung ATIV Book 9 Lite Audio Port Replacement, Audio Port/USB2/Display Port Board: adım 1, 2 resimden 1. Samsung ATIV Book 9 Lite Audio Port Replacement, Audio Port/USB2/Display Port Board: adım 1, 2 resimden 2.
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Audio Port Replacement: adım 2, 3 resimden 1. Samsung ATIV Book 9 Lite Audio Port Replacement: adım 2, 3 resimden 2. Samsung ATIV Book 9 Lite Audio Port Replacement: adım 2, 3 resimden 3.
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Audio Port Replacement: adım 3, 3 resimden 1. Samsung ATIV Book 9 Lite Audio Port Replacement: adım 3, 3 resimden 2. Samsung ATIV Book 9 Lite Audio Port Replacement: adım 3, 3 resimden 3.
    • Using your hands move the black and white wires that are layered on top of the board to be out of the way of the removal.
    • Using a Phillips #0, remove three 3.5mm screws.
  4. Samsung ATIV Book 9 Lite Audio Port Replacement: adım 4, 2 resimden 1. Samsung ATIV Book 9 Lite Audio Port Replacement: adım 4, 2 resimden 2.
    • Using your hands remove the cord that connects the speakers to the board you are removing.
    • Do not pull on the cord as that might damage it; remove it by pulling on the white wire head.
    • Using your hands, remove the board from the computer.
Sonuç
Phat Tran
786 İtibar
5 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 518
