Ana içeriğe geç
Samsung ATIV Book 9 Lite Battery Replacement
Neye ihtiyacın var
  1. Samsung ATIV Book 9 Lite Battery Replacement, Battery: adım 1, 2 resimden 1. Samsung ATIV Book 9 Lite Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Battery Replacement: adım 2, 3 resimden 1. Samsung ATIV Book 9 Lite Battery Replacement: adım 2, 3 resimden 2. Samsung ATIV Book 9 Lite Battery Replacement: adım 2, 3 resimden 3.
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Battery Replacement: adım 3, 3 resimden 1. Samsung ATIV Book 9 Lite Battery Replacement: adım 3, 3 resimden 2. Samsung ATIV Book 9 Lite Battery Replacement: adım 3, 3 resimden 3.
    • Using a Phillips #0, remove the seven 5mm screws highlighted in the image.
    • Using your hands, disconnect the battery's main cord from the main motherboard.
  4. Samsung ATIV Book 9 Lite Battery Replacement: adım 4, 2 resimden 1. Samsung ATIV Book 9 Lite Battery Replacement: adım 4, 2 resimden 2.
    • Using your hands remove the battery from the computer.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Phat Tran
786 İtibar
5 adet Kılavuz yazıldı
Ekip
2 Yorum
please where can i get the battery 🔋
Bethel Ugwudike - Yanıt
Please where can i get the battery for Samsung 930x5j910s5j940x5j
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 1,724
