Ana içeriğe geç
Samsung ATIV Book 9 Lite Hard Drive Replacement
Neye ihtiyacın var
  1. Samsung ATIV Book 9 Lite Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. Samsung ATIV Book 9 Lite Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Hard Drive Replacement: adım 2, 3 resimden 1. Samsung ATIV Book 9 Lite Hard Drive Replacement: adım 2, 3 resimden 2. Samsung ATIV Book 9 Lite Hard Drive Replacement: adım 2, 3 resimden 3.
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Hard Drive Replacement: adım 3, 3 resimden 1. Samsung ATIV Book 9 Lite Hard Drive Replacement: adım 3, 3 resimden 2. Samsung ATIV Book 9 Lite Hard Drive Replacement: adım 3, 3 resimden 3.
    • Using your hands or a plastic opening tool, release the yellow motherboard connection strip on both ends by lifting the clamps.
    • Remove the strip to reveal the hard drive.
  4. Samsung ATIV Book 9 Lite Hard Drive Replacement: adım 4, 2 resimden 1. Samsung ATIV Book 9 Lite Hard Drive Replacement: adım 4, 2 resimden 2.
    • Using a Phillips #0, remove the two 3mm screws holding the hard drive in place.
    • Remove the hard drive by pulling it out with your hands.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Phat Tran
786 İtibar
5 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 34
Her zaman: 4,546
