Ana içeriğe geç
Samsung ATIV Book 9 Plus Charger Port Replacement
Neye ihtiyacın var
  1. Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: adım 1, 3 resimden 1. Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: adım 1, 3 resimden 2. Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: adım 1, 3 resimden 3.
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Charger Port Replacement: adım 2, 1 resimden 1.
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: adım 3, 2 resimden 1. Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: adım 3, 2 resimden 2.
    • Unscrew the 4.3mm screws holding down the plastic cover using a #000 screwdriver. After the screws are out remove the cover.
    • Remove the 4.3 mm screw holding down the metal cover using a #000 screwdriver.
  4. Samsung ATIV Book 9 Plus Charger Port Replacement: adım 4, 1 resimden 1.
    • Disconnect the charging port from the motherboard by gently tugging on the plastic part of the connection.
  5. Samsung ATIV Book 9 Plus Charger Port Replacement: adım 5, 1 resimden 1.
    • Wedge a plastic opening tool or spudger in between the laptop casing and the port. Pry until you feel it release.
    • This will take some force because the port is glued to the casing.
  6. Samsung ATIV Book 9 Plus Charger Port Replacement: adım 6, 1 resimden 1.
    • Remove the disconnected charger port.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Casey Kauffman
329 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S6-G6, Baechle Fall 2017 IUPUI, Team S6-G6, Baechle Fall 2017 üyesi
IUPUI-BAECHLE-F17S6G6
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 1,927
