Ana içeriğe geç
Samsung ATIV Book 9 Plus Heatsink Assembly Replacement
Neye ihtiyacın var
  1. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: adım 1, 3 resimden 1. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: adım 1, 3 resimden 2. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: adım 1, 3 resimden 3.
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: adım 2, 1 resimden 1.
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: adım 3, 3 resimden 1. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: adım 3, 3 resimden 2. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: adım 3, 3 resimden 3.
    • The fans should be in the upper left corner of the laptop if the laptop is oriented with the battery in the bottom half.
    • Gently lift the fans' black connector strip out of the way.
  4. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: adım 4, 2 resimden 1. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: adım 4, 2 resimden 2.
    • Using a Phillips head screwdriver, unscrew four 4.55 mm Phillips #000 screws that bind the fans.
  5. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: adım 5, 1 resimden 1.
    • Disconnect the white connectors by gently tugging on them.
    • Lift the fans from their positions.
  6. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Heatsink Assembly: adım 6, 1 resimden 1.
    • Using a Phillips head screwdriver #000 unscrew the motherboard from the rest of the components.
  7. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: adım 7, 1 resimden 1.
    • Disconnect the two cables shown in the picture by gently pulling them off.
  8. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: adım 8, 1 resimden 1.
    • Using a Phillips #000 screwdriver, unscrew the three labeled screws to detach the heatsink assembly.
Sonuç
Ryan Smith
193 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S7-G7, Wilson Spring 2019 IUPUI, Team S7-G7, Wilson Spring 2019 üyesi
IUPUI-WILSON-S19S7G7
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 638
