Ana içeriğe geç
Samsung ATIV Book 9 Plus Internal Fans Replacement
Neye ihtiyacın var
  1. Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: adım 1, 3 resimden 1. Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: adım 1, 3 resimden 2. Samsung ATIV Book 9 Plus Internal Fans Replacement, Back Cover: adım 1, 3 resimden 3.
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Internal Fans Replacement: adım 2, 1 resimden 1.
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: adım 3, 3 resimden 1. Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: adım 3, 3 resimden 2. Samsung ATIV Book 9 Plus Internal Fans Replacement, Internal Fans: adım 3, 3 resimden 3.
    • The fans should be in the upper left corner of the laptop if the laptop is oriented with the battery in the bottom half.
    • Gently lift the fans' black connector strip out of the way.
  4. Samsung ATIV Book 9 Plus Internal Fans Replacement: adım 4, 2 resimden 1. Samsung ATIV Book 9 Plus Internal Fans Replacement: adım 4, 2 resimden 2.
    • Using a Phillips head screwdriver, unscrew four 4.55 mm Phillips #000 screws that bind the fans.
  5. Samsung ATIV Book 9 Plus Internal Fans Replacement: adım 5, 1 resimden 1.
    • Disconnect the white connectors by gently tugging on them.
    • Lift the fans from their positions.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Rhannie Surel
137 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 2-3, Grigsby Spring 2015 Baylor, Team 2-3, Grigsby Spring 2015 üyesi
BU-GRIGSBY-S15S2G3
4 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
I think that's to easy!
Ocean - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 4,509
