Ana içeriğe geç
Samsung ATIV Book 9 Plus Keys Replacement
Neye ihtiyacın var
    1. Samsung ATIV Book 9 Plus Keys Replacement, Keys: adım 1, 2 resimden 1. Samsung ATIV Book 9 Plus Keys Replacement, Keys: adım 1, 2 resimden 2.
      • Open your laptop so your keyboard is facing you and is easily accessible.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung ATIV Book 9 Plus Keys Replacement: adım 2, 3 resimden 1. Samsung ATIV Book 9 Plus Keys Replacement: adım 2, 3 resimden 2. Samsung ATIV Book 9 Plus Keys Replacement: adım 2, 3 resimden 3.
      • Using a plastic opening tool, carefully push the thin tip under the key.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung ATIV Book 9 Plus Keys Replacement: adım 3, 2 resimden 1. Samsung ATIV Book 9 Plus Keys Replacement: adım 3, 2 resimden 2.
      • Pivot the tool upwards. This should pry the key away from the keyboard.
      • Hearing some snapping sounds should be normal as the key lifts away from its attachments.
      • Continue lifting the tool until the key comes away completely or gently pull the key off. Repeat for other keys as needed.
      • Be gentle, as the attachments may accidentally break with rough handling.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
unknown
261 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 2-3, Grigsby Spring 2015 Baylor, Team 2-3, Grigsby Spring 2015 üyesi
BU-GRIGSBY-S15S2G3
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 6,585
