Ana içeriğe geç
Samsung ATIV Book 9 Plus Keys Replacement
Neye ihtiyacın var
  1. Samsung ATIV Book 9 Plus Keys Replacement, Keys: adım 1, 2 resimden 1. Samsung ATIV Book 9 Plus Keys Replacement, Keys: adım 1, 2 resimden 2.
    • Open your laptop so your keyboard is facing you and is easily accessible.
  2. Samsung ATIV Book 9 Plus Keys Replacement: adım 2, 3 resimden 1. Samsung ATIV Book 9 Plus Keys Replacement: adım 2, 3 resimden 2. Samsung ATIV Book 9 Plus Keys Replacement: adım 2, 3 resimden 3.
    • Using a plastic opening tool, carefully push the thin tip under the key.
  3. Samsung ATIV Book 9 Plus Keys Replacement: adım 3, 2 resimden 1. Samsung ATIV Book 9 Plus Keys Replacement: adım 3, 2 resimden 2.
    • Pivot the tool upwards. This should pry the key away from the keyboard.
    • Hearing some snapping sounds should be normal as the key lifts away from its attachments.
    • Continue lifting the tool until the key comes away completely or gently pull the key off. Repeat for other keys as needed.
    • Be gentle, as the attachments may accidentally break with rough handling.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
unknown
261 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 2-3, Grigsby Spring 2015 Baylor, Team 2-3, Grigsby Spring 2015 üyesi
BU-GRIGSBY-S15S2G3
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 14
Her zaman: 6,145
