Ana içeriğe geç
Samsung ATIV Book 9 Plus Speakers Replacement
Neye ihtiyacın var
  1. Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: adım 1, 3 resimden 1. Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: adım 1, 3 resimden 2. Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: adım 1, 3 resimden 3.
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Speakers Replacement: adım 2, 1 resimden 1.
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Speakers Replacement, Speakers: adım 3, 2 resimden 1. Samsung ATIV Book 9 Plus Speakers Replacement, Speakers: adım 3, 2 resimden 2.
    • The speakers are black, and form a block-like "L" shape around the bottom half of the battery.
    • Lift from the corners of the speakers to remove them.
  4. Samsung ATIV Book 9 Plus Speakers Replacement: adım 4, 2 resimden 1. Samsung ATIV Book 9 Plus Speakers Replacement: adım 4, 2 resimden 2.
    • After lifting the body of the speaker out of the laptop, you will notice that the top of the speaker is connected to the laptop by cables.
    • Continue removing the speakers by gently squeezing the sides of the white connector.
  5. Samsung ATIV Book 9 Plus Speakers Replacement: adım 5, 1 resimden 1.
    • Gently tug on the white connector in order to remove the speakers.
Sonuç
Karoline DaVee
136 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 2-3, Grigsby Spring 2015 Baylor, Team 2-3, Grigsby Spring 2015 üyesi
BU-GRIGSBY-S15S2G3
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 1,485
