Ana içeriğe geç
Samsung ATIV Book 9 Plus Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Samsung ATIV Book 9 Plus Wi-Fi Card Replacement, Back Cover: adım 1, 3 resimden 1. Samsung ATIV Book 9 Plus Wi-Fi Card Replacement, Back Cover: adım 1, 3 resimden 2. Samsung ATIV Book 9 Plus Wi-Fi Card Replacement, Back Cover: adım 1, 3 resimden 3.
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Wi-Fi Card Replacement: adım 2, 1 resimden 1.
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Wi-Fi Card Replacement, Wi-Fi Card: adım 3, 1 resimden 1.
    • Gently pull off both cables attached to Wi-Fi card.
  4. Samsung ATIV Book 9 Plus Wi-Fi Card Replacement: adım 4, 1 resimden 1.
    • Unscrew the labeled screw using a Phillips #000 screwdriver.
  5. Samsung ATIV Book 9 Plus Wi-Fi Card Replacement: adım 5, 1 resimden 1.
    • Pull Wi-Fi card out to completely detach it.
Sonuç
Ryan Smith
193 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S7-G7, Wilson Spring 2019 IUPUI, Team S7-G7, Wilson Spring 2019 üyesi
IUPUI-WILSON-S19S7G7
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 818
