Ana içeriğe geç
Samsung Ace Antenna Replacement
Neye ihtiyacın var
  1. Samsung Ace Antenna Replacement, Battery: adım 1, 3 resimden 1. Samsung Ace Antenna Replacement, Battery: adım 1, 3 resimden 2. Samsung Ace Antenna Replacement, Battery: adım 1, 3 resimden 3.
    • To remove the back casing, firmly press down and push towards the bottom of the phone.
  2. Samsung Ace Antenna Replacement: adım 2, 1 resimden 1.
    • With the casing removed, lift the battery from the indicated indentation.
  3. Samsung Ace Antenna Replacement: adım 3, 1 resimden 1.
    • From here, you can now access the SIM card and model/serial numbers.
  4. Samsung Ace Antenna Replacement, Casing: adım 4, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the four indicated screws (4.5 mm).
  5. Samsung Ace Antenna Replacement: adım 5, 2 resimden 1. Samsung Ace Antenna Replacement: adım 5, 2 resimden 2.
    • Press the pointed edge of the spudger into the side of the two rubber plugs in order to lift and remove them from the top of the phone.
    • Then, using the Phillips #00 screwdriver, remove the two indicated Phillip screws (6.5 mm).
  6. Samsung Ace Antenna Replacement: adım 6, 1 resimden 1.
    • To remove the SIM card, start by pressing the top of the card and push down and away towards the bottom of the phone. Then, as indicated, pull the SIM card out.
  7. Samsung Ace Antenna Replacement: adım 7, 2 resimden 1. Samsung Ace Antenna Replacement: adım 7, 2 resimden 2.
    • Begin to slowly lift the back casing of the phone. You should hear a snap when the casing is released.
    • The power, volume, and camera buttons may fall out when separating the front and back casing.
  8. Samsung Ace Antenna Replacement: adım 8, 1 resimden 1.
    • Your casing should be separated and the three loose buttons put to the side.
    • Be aware of the wiring on the top of the phone. Make sure not to pull it apart when separating the case.
  9. Samsung Ace Antenna Replacement: adım 9, 2 resimden 1. Samsung Ace Antenna Replacement: adım 9, 2 resimden 2.
    • Slowly remove the back casing by gently pulling the ribbon connection.
  10. Samsung Ace Antenna Replacement: adım 10, 2 resimden 1. Samsung Ace Antenna Replacement: adım 10, 2 resimden 2.
    • Gently pull on the wires to remove the front casing.
  11. Samsung Ace Antenna Replacement: adım 11, 1 resimden 1.
    • Your front casing and front speaker are now released.
  12. Samsung Ace Antenna Replacement, Antenna: adım 12, 1 resimden 1.
    • Remove the two indicated screws (3.9 mm) with a Phillips #00 screwdriver.
  13. Samsung Ace Antenna Replacement: adım 13, 1 resimden 1.
    • Gently pull up the antenna.
    • Be aware of the connected wire along the side of the phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Garrett Germany
24 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-24, Amido Spring 2012 Cal Poly, Team 6-24, Amido Spring 2012 üyesi
CPSU-AMIDO-S12S6G24
3 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 2,026
