Ana içeriğe geç
Samsung Ace Display Screen Replacement
Neye ihtiyacın var
  1. Samsung Ace Display Screen Replacement, Battery: adım 1, 3 resimden 1. Samsung Ace Display Screen Replacement, Battery: adım 1, 3 resimden 2. Samsung Ace Display Screen Replacement, Battery: adım 1, 3 resimden 3.
    • To remove the back casing, firmly press down and push towards the bottom of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Ace Display Screen Replacement: adım 2, 1 resimden 1.
    • With the casing removed, lift the battery from the indicated indentation.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Ace Display Screen Replacement: adım 3, 1 resimden 1.
    • From here, you can now access the SIM card and model/serial numbers.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Ace Display Screen Replacement, Casing: adım 4, 1 resimden 1.
    • Using the Phillips #00 screwdriver, remove the four indicated screws (4.5 mm).
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Ace Display Screen Replacement: adım 5, 2 resimden 1. Samsung Ace Display Screen Replacement: adım 5, 2 resimden 2.
    • Press the pointed edge of the spudger into the side of the two rubber plugs in order to lift and remove them from the top of the phone.
    • Then, using the Phillips #00 screwdriver, remove the two indicated Phillip screws (6.5 mm).
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Ace Display Screen Replacement: adım 6, 1 resimden 1.
    • To remove the SIM card, start by pressing the top of the card and push down and away towards the bottom of the phone. Then, as indicated, pull the SIM card out.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Ace Display Screen Replacement: adım 7, 2 resimden 1. Samsung Ace Display Screen Replacement: adım 7, 2 resimden 2.
    • Begin to slowly lift the back casing of the phone. You should hear a snap when the casing is released.
    • The power, volume, and camera buttons may fall out when separating the front and back casing.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Ace Display Screen Replacement: adım 8, 1 resimden 1.
    • Your casing should be separated and the three loose buttons put to the side.
    • Be aware of the wiring on the top of the phone. Make sure not to pull it apart when separating the case.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Ace Display Screen Replacement: adım 9, 2 resimden 1. Samsung Ace Display Screen Replacement: adım 9, 2 resimden 2.
    • Slowly remove the back casing by gently pulling the ribbon connection.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Ace Display Screen Replacement: adım 10, 2 resimden 1. Samsung Ace Display Screen Replacement: adım 10, 2 resimden 2.
    • Gently pull on the wires to remove the front casing.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung Ace Display Screen Replacement: adım 11, 1 resimden 1.
    • Your front casing and front speaker are now released.
    FixBot'a Sor
    Yorum Ekle
  12. Samsung Ace Display Screen Replacement, Display Screen: adım 12, 2 resimden 1. Samsung Ace Display Screen Replacement, Display Screen: adım 12, 2 resimden 2.
    • Locate the display screen.
    • Carefully squeeze part of the flat or pointed edge of the spudger into the spacing under the glass display to pry and lift the display up.
    • It may help to insert the pointed edge of the spudger into the small indentation shown on the right in the second image.
    FixBot'a Sor
    Yorum Ekle
  13. Samsung Ace Display Screen Replacement: adım 13, 3 resimden 1. Samsung Ace Display Screen Replacement: adım 13, 3 resimden 2. Samsung Ace Display Screen Replacement: adım 13, 3 resimden 3.
    • Slide the spudger across the bottom of the display and slowly push up.
    FixBot'a Sor
    Yorum Ekle
  14. Samsung Ace Display Screen Replacement: adım 14, 1 resimden 1.
    • Slowly pry the spudger up to remove the display.
    FixBot'a Sor
    Yorum Ekle
  15. Samsung Ace Display Screen Replacement: adım 15, 1 resimden 1.
    • To remove the casing as a whole, slowly lift up and towards the right side of the phone.
    • Be aware of the wiring on the right side of the phone connecting the display.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Breanne
187 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-24, Amido Spring 2012 Cal Poly, Team 6-24, Amido Spring 2012 üyesi
CPSU-AMIDO-S12S6G24
3 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 28
Her zaman: 1,857
