Ana içeriğe geç
Samsung Admire Screen Replacement
Neye ihtiyacın var
  1. Samsung Admire Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Slide your fingernail or plastic opening tool under the slit and pull the cover up.
  2. Samsung Admire Screen Replacement: adım 2, 1 resimden 1.
    • Place your fingernail or plastic tool into the hole beneath the camera and carefully lift out the battery.
  3. Samsung Admire Screen Replacement: adım 3, 3 resimden 1. Samsung Admire Screen Replacement: adım 3, 3 resimden 2. Samsung Admire Screen Replacement: adım 3, 3 resimden 3.
    • Use a Phillips #00 precision screwdriver to remove the six screws from the back of the phone.
  4. Samsung Admire Screen Replacement: adım 4, 3 resimden 1. Samsung Admire Screen Replacement: adım 4, 3 resimden 2. Samsung Admire Screen Replacement: adım 4, 3 resimden 3.
    • Use the plastic opening tool to remove the inside back cover.
    • Use the plastic opening to pry the front and the back case apart.
    • As you lift the cover, move the plastic tool around the phone to pry up all of the screen.
    • Carefully disconnect the ribbon cables and slowly lift the inside back cover to remove it.
  5. Samsung Admire Screen Replacement: adım 5, 3 resimden 1. Samsung Admire Screen Replacement: adım 5, 3 resimden 2. Samsung Admire Screen Replacement: adım 5, 3 resimden 3.
    • Lift the motherboard slowly.
    • Carefully disconnect the volume button from the motherboard.
    • Disconnect the two ribbon cables from the back of the motherboard.
  6. Samsung Admire Screen Replacement: adım 6, 3 resimden 1. Samsung Admire Screen Replacement: adım 6, 3 resimden 2. Samsung Admire Screen Replacement: adım 6, 3 resimden 3.
    • Pull back on the five clips on the sides of the phone to remove the shield.
    • Be careful not to break the ribbon cables.
  7. Samsung Admire Screen Replacement: adım 7, 3 resimden 1. Samsung Admire Screen Replacement: adım 7, 3 resimden 2. Samsung Admire Screen Replacement: adım 7, 3 resimden 3.
    • Use the plastic opening tool to unlatch the ribbon cable to disconnect it.
    • Place the plastic opening tool under the edge of the screen and lift the screen up carefully.
  8. Samsung Admire Screen Replacement: adım 8, 1 resimden 1.
    • Insert new screen into the phone frame and reconnect the ribbon cable.
    • Follow steps in reverse order (omitting step eight) to reassemble the phone.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Thao Uyen Do
926 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-5, Remmell Winter 2015 USF Tampa, Team 7-5, Remmell Winter 2015 üyesi
USFT-REMMELL-W15S7G5
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 1,882
