Ana içeriğe geç
Samsung Admire Speaker Replacement
Neye ihtiyacın var
  1. Samsung Admire Speaker Replacement, Back Cover: adım 1, 1 resimden 1.
    • Use your fingernail or plastic opening tool to pull up the back cover of the phone from under the slit.
  2. Samsung Admire Speaker Replacement, Remove the battery: adım 2, 1 resimden 1.
    • Carefully remove the battery by placing your fingernail underneath the hole and pulling out the battery.
    • Your hands should not be wet.
  3. Samsung Admire Speaker Replacement, Remove the screws: adım 3, 3 resimden 1. Samsung Admire Speaker Replacement, Remove the screws: adım 3, 3 resimden 2. Samsung Admire Speaker Replacement, Remove the screws: adım 3, 3 resimden 3.
    • Use the Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
  4. Samsung Admire Speaker Replacement, Inside back cover: adım 4, 3 resimden 1. Samsung Admire Speaker Replacement, Inside back cover: adım 4, 3 resimden 2. Samsung Admire Speaker Replacement, Inside back cover: adım 4, 3 resimden 3.
    • Use the plastic opening tools to remove the inside back cover.
    • Place the plastic opening tools on the outside rim of the inside back cover.
    • Carefully lift the cover and circle around the rim to open the inside back cover completely.
    • Carefully disconnect ribbon cables and slowly lift the inside back cover to remove it.
  5. Samsung Admire Speaker Replacement, Speaker: adım 5, 2 resimden 1. Samsung Admire Speaker Replacement, Speaker: adım 5, 2 resimden 2.
    • The speaker is located within the inside of the back cover.
    • Simply remove it by lifting it off with the plastic opening tool.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Thao Uyen Do
914 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-5, Remmell Winter 2015 USF Tampa, Team 7-5, Remmell Winter 2015 üyesi
USFT-REMMELL-W15S7G5
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 789
