Ana içeriğe geç
Samsung Alias 2 Camera Replacement
Neye ihtiyacın var
  1. Samsung Alias 2 Camera Replacement, Battery: adım 1, 1 resimden 1.
    • Press down on the back cover of the phone and remove it.
  2. Samsung Alias 2 Camera Replacement: adım 2, 1 resimden 1.
    • Take out the battery from the device.
  3. Samsung Alias 2 Camera Replacement, Camera: adım 3, 1 resimden 1.
    • Remove the (2) 4.1 mm screws on screen.
  4. Samsung Alias 2 Camera Replacement: adım 4, 3 resimden 1. Samsung Alias 2 Camera Replacement: adım 4, 3 resimden 2. Samsung Alias 2 Camera Replacement: adım 4, 3 resimden 3.
    • Remove front outside casing with plastic opening tools.
  5. Samsung Alias 2 Camera Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the camera from its holding slot.
  6. Samsung Alias 2 Camera Replacement: adım 6, 1 resimden 1.
    • Use a plastic opening tool to lift the tab that holds the camera ribbon in place.
  7. Samsung Alias 2 Camera Replacement: adım 7, 1 resimden 1.
    • Use tweezers to remove the camera.
  8. Samsung Alias 2 Camera Replacement: adım 8, 1 resimden 1.
    • Slide ribbon of new camera under the same tab.
  9. Samsung Alias 2 Camera Replacement: adım 9, 1 resimden 1.
    • Close the tab down onto the new camera ribbon.
  10. Samsung Alias 2 Camera Replacement: adım 10, 1 resimden 1.
    • Use tweezers to put the new camera into the camera slot that previously held the old camera.
    • WARNING: Do not touch the camera lens as it will easily scratch or smudge.
Sonuç
Chris
133 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-35, Maness Spring 2011 Cal Poly, Team 12-35, Maness Spring 2011 üyesi
CPSU-MANESS-S11S12G35
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 20
Her zaman: 2,340
